12-15-2017, 06:12 AM | #21 |
| Re: Soze's Axial Yeti Kit Progress tracker.
Curious to see how that centered axle works out. I was looking at adding that to mine as well.
12-15-2017, 06:33 AM | #22 |
I too didn’t care for the yeti look..... so a raptor body went over the SSD centered rear axle. Eliminated a bunch of handling issues seems to help keeping rear on the ground also. Hang up and Drive |
12-18-2017, 12:11 AM | #23 |
So everything seems to be 1 step forward 3 steps backward for me lately. I got a bunch of the screws replaced on the Yeti using the Team KNK screw kit. I ended up not using some of them, because I have upgraded parts in certain areas that came with hardware that were different from stock. Put together the Incision upper rear links. Put together the SSD RC HD D60 Centered Rear Axle Case... Then FML happened. Somehow the bracket for the upper links split while I was screwing in the screw to attach the upper links. I'm stuck with a useless axle housing now unless I can get a replacement upper link mount/truss... or buy another complete set. Really bummed. Wanted to get this project out of the way, because I know work is going to be painful for me for the next several weeks. Won't have time to do anything. |
12-18-2017, 03:40 AM | #24 | |
RCC Addict Join Date: Mar 2011 Location: easton
| Re: Soze's Axial Yeti Kit Progress tracker. Quote:
Try contacting ssd and see if they can do anything to help you out Sent from my iPhone using Tapatalk | |
12-18-2017, 10:22 AM | #25 |
| Re: Soze's Axial Yeti Kit Progress tracker. Yes, already did. Chris sorted me out. Glad I went with SSD. They've got me as a customer now. The axle housing and the trailing arms are my first SSD products and won't be my last.
12-18-2017, 11:23 AM | #26 |
Chris is a fine guy( bloke?) Will take great care of you. Hang up and Drive |
12-18-2017, 12:55 PM | #27 |
Quarry Creeper Join Date: Jun 2012 Location: Washougal
Watching closely, making me want to work on mine as well
12-18-2017, 01:12 PM | #28 | |
Rock Crawler Join Date: Apr 2017 Location: Northeast PA
Thanks | |
12-18-2017, 01:17 PM | #29 |
I had issues with torque, it didn’t lift and twist, just caused wandering. I run a Tekin 4x4HD 3000. The little difference in weight( trusses and beef tubes) didn’t do much different. The extra wide though has saved bearings and axles so far, as I have spares . Hang up and Drive |
12-19-2017, 06:50 PM | #30 |
So here are some pictures of my progress before my SSD axle mishap. I've ordered a second axle housing while I wait for the replacement part as I can use the additional axle housing for the Bomber or Wraith that I also have yet to build. Team KNK Screw Kit SSD HD D60 Centered Axle Housing (before my misshap with the link mount) with SSD Wide D60 Conversion Kit Progress with the Team KNK screws... Yeti in pieces... Found this when I took off the arms... I can only think of one time where I actually had any sort of impact and it wasn't that bad... weak ass screws. Bought some Axial AXA0128 M3x61mm replacements... I'll have to sleeve these like I've read others have done... or figure something out. Xtra Speed 56T Spur gear going in... Those Vanquish slipper plates won't work, I mistakenly got the Wraith ones.... which I'll now use on the Wraith. Spur in... didn't take a picture with the mesh adjusted yet. More pictures of screw replacement progress. About to put the upgraded Incision Upper links and SSD Trailing arms on before I ran into my mishap. Last edited by soze; 12-04-2019 at 11:18 PM. |
12-27-2017, 12:25 AM | #31 |
Got some of the updates done over the holidays... Was going to sleeve the stock pins, but instead went with M3x60mm 12.9pt screws that I found SSD Trailing arms and Incision Upper links installed and mounted onto the SSD HD D60 Axle. Comparison of stock arm vs RPM arms Comparison of stock pins (left) vs the new 12.9pt screws (right) Vanquish Skid Plate 12.9pt screws, RPM arms and Vanquish Skid Plate installed Last edited by soze; 12-04-2019 at 11:22 PM. |
03-09-2018, 12:22 AM | #32 |
So, I was ordering some Orlandoo Hunter parts off Asiatees and I decided to just throw in some Boom Racing Aluminum parts for the Yeti to get my cart to a certain dollar amount for shipping. Boom Racing Aluminum Steering Knuckle Caster Block Boom Racing Aluminum Steering Knuckle Boom Racing Aluminum Rear Upper Shock Mount Check out my warped plastic shock mount. Shock mount installed Steering Knuckle and Caster Block |
Soze's Axial Yeti Kit Progress tracker. - Similar Threads | ||||
Soze's GMade Sawback 4LS | soze | G-Made Sawback | 23 | 12-31-2021 12:59 PM |
Soze's GMADE GOM GR01 Build | soze | G-Made Crawlers | 69 | 08-20-2021 12:45 AM |
Soze's MST CFX-W Build | soze | Max Speed Technology CFX | 90 | 01-31-2019 01:02 AM |
My Yeti build in progress | GrimReaper187 | Axial Yeti | 6 | 07-07-2016 03:40 PM |
Axial RTR - Making Progress | Houndog | Videos! | 0 | 05-24-2008 05:40 PM |
