03-14-2018, 07:29 AM | #21 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Vanquish Yeti Bulkhead
thx svt. found it on the bay a few days ago but was sold out..... and also out of stock at vanquish direct.... Last edited by magic_yeti; 03-14-2018 at 09:56 AM. |
03-14-2018, 04:16 PM | #22 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
I need two of these, and the newer version of the scx trans in clear anodizing, they’ll either go into my blue monkey rc full independent suspension wraith, or it’ll be time to see if the DMG still has that B2B bomber kit in production.
03-14-2018, 04:43 PM | #23 |
This looks great. Expensive though.
04-27-2018, 07:50 AM | #24 |
Rock Stacker Join Date: Feb 2017 Location: Finland
Anybody who has installed Vanquish bulkhead to Exo rear end. With the stock setup the toe blocks lift up the rear arms front side putting the rear end up to an upward angle....using the Vanquish bulkhead the pin support part forces this angle to be level or even downward a bit. It is easy to install just using another set of Exo front toe blocks, but have noticed any negative impact on handling/suspension?
07-28-2019, 01:31 PM | #25 |
Newbie Join Date: Jul 2019 Location: Mission Viejo
Do they come with bearings or do the stock ones work ?
07-28-2019, 02:05 PM | #26 | |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
| Re: Vanquish Yeti Bulkhead Quote:
Got you pics of this issue? | |
07-28-2019, 07:24 PM | #27 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: Vanquish Yeti Bulkhead |
07-28-2019, 10:07 PM | #28 |
Thanks I just purchased one from Amain hobbies Sent from my iPhone using Tapatalk |
09-25-2019, 10:02 AM | #29 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
A big benefit I see along with the bigger bearing and great looks is that it supports the A arm hinge pin so no more bent hinge pins if you use this.
Vanquish Yeti Bulkhead - Similar Threads | ||||
Axial Yeti XL and Hot Racing Bulkhead | SeanKewley | Axial Yeti XL | 20 | 05-16-2018 11:47 PM |
All Vanquish Yeti XL... | BigBaller | Axial Yeti XL | 10 | 12-05-2014 10:39 PM |
