03-17-2018, 05:25 PM | #1 |
Newbie Join Date: Jan 2015 Location: Weston,Florida
| Making the Yeti mine
So I have always wanted the Yeti, I have a few different RC’s from Axial I own the Exo.. so I pulled the trigger and got a bunch parts and this what I came up out with. I will give a list of my parts if anyone would like. A big difference is the choice of tires I made compared to most rock racers but is going to do a lot of pavement running. Mostly Vanquish stuff. Need to switch shocks out.. I see the prolines are popular.. any other suggestions. The stock servo.. didn’t last long, plastic one lost some teeth.. Smh How do you guys feel about the Spektrum S6270?? Last edited by THX_138; 07-29-2018 at 05:49 AM. Reason: Images re-sized....images grossly oversized |
03-17-2018, 05:43 PM | #2 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
| Re: Making the Yeti mine
I apologize for being blunt..... but those tires don’t go with the concept of the vehicle
03-17-2018, 06:33 PM | #3 | |
| Making the Yeti mine Quote:
No apology needed I don’t take it personal everyone has an opinion and this hooby is for you to experiment with all the options available. I am not running it in the dirt or rocks, just pavement the “crawler tires” don’t hold very good in pavement. I have them there when I get to terrain that will benefit from it. NYC winters keep me from going to a park or rougher terrain.. so I run it on my street waiting for the summer. Last edited by Jeanethics; 03-17-2018 at 06:36 PM. | |
03-17-2018, 07:24 PM | #4 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
A top- and nose-heavy truck like the yeti is not an ideal choice for high-traction surfaces, but in this case it may benefit from a front (Exo) sway bar. This will reduce the tendency of the yeti to lift the inside rear wheel in corners. It will still roll, but it will lift both tires, and suddenly. I tried this on my yeti, but then realized that there are better vehicles for the street and track. The proline shocks typically sag under the weight of the yeti, as they come with rates intended for lighter SCTs. The Spektrum S6270 looks underpowered for the nose-heavy yeti. I have a 1210SG and I would not want it less powerful (or slower). |
03-18-2018, 10:30 AM | #5 | |
| Re: Making the Yeti mine Quote:
I will try the exo sway bar I have one here lying around thanks for the advice on that. I was looking for information on that. Your right There is other vehicles that are far better for Street and track.. but I’ll be honest as it sits now I am having a blast with it (until I stripped the servo *) Yeah I see that comment about the prolines a lot do you know if any other options ? Oh ok cool I actually seen the 1210sg I guess I will give that a run and it’son sale like 10 bucks cheaper than the Spektrum. Thanks for advice | |
03-18-2018, 01:00 PM | #6 | ||
03-19-2018, 07:53 AM | #7 | |
Thanks Stray, I appreciate the kind words. I really don't take it personal at all everyone has there opinions, I decide what to do with my money.. It's for me to play with not for it to be accepted. I have looked into hard compounds, I honestly think that would be a cool option to have it slide out more. What tires did you get with the harder compounds? Thanks for the f150 suggestion is on my list to buy next. I have had pretty good luck with it the way its setup now.. no flipping at all. I can use the hard springs for sure. I also plan to use the exo sway bar as suggested.. Its pretty fast I was actually surprised.. | |
03-19-2018, 02:22 PM | #8 | |
Quarry Creeper Join Date: Feb 2018 Location: Melbourne Australia
Sent from my LG-H870DS using Tapatalk | |
03-19-2018, 06:17 PM | #9 |
| Re: Making the Yeti mine |
03-21-2018, 12:07 PM | #10 |
Note that the proline 2.8 tire-wheel combos are typically available in two different offsets, so check to see which best suits your purposes.
03-21-2018, 06:26 PM | #11 | |
Thanks David.. Got that 1210SG wow is all I can say that thing is night and day difference, thinking of switching the servos on all my other rc’s.... | |
04-01-2018, 10:24 PM | #12 |
So I got the servo in..it works great. I have a new dilemma .. My fellow RC Crawlers and that is I got a Mamba X and a new motor as well but the can is to long for the space provided. Is the only option cutting into the battery tray or is there another solution. Any help is appreciated Last edited by THX_138; 07-29-2018 at 05:52 AM. |
04-02-2018, 09:49 AM | #13 |
A shorter motor.
04-02-2018, 03:34 PM | #14 |
04-02-2018, 03:58 PM | #15 |
Heaps of people just cut the battery tray, it depends on if you want to use the sensor... Id buy the stock part as a spare(incase you stuff it up, or can't actually make it work) , then hack up your current one and see if you can make it fit. I reckon that's all part of the fun. Sent from my LG-H870DS using Tapatalk |
04-02-2018, 04:29 PM | #16 |
Easy enough, just make sure it's 32p Sent from my LG-H870DS using Tapatalk |
04-05-2018, 11:55 PM | #17 |
Got some 32p with the 3mm bore...
04-07-2018, 01:17 AM | #18 |
Cleaned up some of the wires ran them all to the right side and put the NVS inside the Fuel Cell. Made all the wires detachable at the top of the battery cage, so I can completely take of the body with out opening the Fuel Cell.
04-12-2018, 04:30 PM | #19 | |
RCC Addict Join Date: Mar 2011 Location: easton
Proline primes are a waste of money, unless that’s the only option. I’ve ran both the road rage and primes on both 2wd and 4wd sct in the street. The primes seemed to have better traction but they didn’t last nearly as long. Sent from my iPhone using Tapatalk | |
04-15-2018, 08:05 PM | #20 |
Hey - for a street/hardpack dirt tire, try a set of RC4WD Dune T/A 2.2" tires - they are a somewhat scale replica of what is actually used in some situations on 1:1 rigs like trophy trucks: https://store.rc4wd.com/Dune-TA-22-O...res_p_719.html |
Making the Yeti mine - Similar Threads | ||||
Yeti xl making strange noise please help | Yetixl2280 | Newbie General | 7 | 04-25-2016 02:33 PM |
this one is mine | jamesdicken | Axial XR10 | 20 | 10-09-2010 06:52 PM |
Mine | mmbackpacker | HPI Wheely King | 3 | 03-06-2008 09:26 PM |
