Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Yeti Score speed increase
Old 03-20-2018, 05:01 AM   #1
Default Yeti Score speed increase
I have a yeti score truck. And I was wanting to know if I could just buy the one set of gears. In the 2-speed kit to make it faster. Or if I have to install the whole kit. I just want it geared to go fast not slow for crawling.
casper975 is offline   Reply With Quote
Old 03-20-2018, 05:57 AM   #2
Default Re: Yeti Score speed increase
The easiest thing would be to get a bigger pinion and/or a smaller spur gear.
TooOldForThis is offline   Reply With Quote
Old 03-20-2018, 07:59 AM   #3
You can also swap your top shaft gear 26 tooth and bottom shaft gear 28 tooth in your transmission.
OhioSuperSport is offline   Reply With Quote
Old 03-20-2018, 09:42 AM   #4
Bigger pinion/smaller spur, is the easiest way. Can also add Axial OD gears front and rear to up the driveline ratio.
OSRC is offline   Reply With Quote
Old 03-20-2018, 11:55 PM   #5
Thanks everyone.
Old 03-21-2018, 01:57 PM   #6
I put a order in for the 21T pinion from robinson racing. And the 26t and 28t gears.
Old 03-21-2018, 06:11 PM   #7
Ive got the regular yeti. Uped the pinion to a 18t and running 3s and it wheelies alot. Haven't done the tranny gear swap. How much does swapping the trans gear make a difference?
Sent from my Moto Z (2) using Tapatalk
wcdfmt510 is offline   Reply With Quote
Old 03-21-2018, 08:06 PM   #8
The transmission will have a slight overdrive after swapping the gears (1.076 vs stock .92
Old 03-21-2018, 08:07 PM   #9
Im gonna swap it tonight.. for more speed right
Old 03-24-2018, 02:10 AM   #10
Not sure if you have the budget, butine screams with a 550 brushless motor around 3500kv and 4s. Running the hobbywing max10sct esc
Sent from my LG-H870DS using Tapatalk
Stray is offline   Reply With Quote
Old 03-28-2018, 08:15 AM   #11
You should see a speed increase.
Old 03-28-2018, 10:24 AM   #12
I believe it is the equivalent of going up from a 16 to a 18T pinion.
DavidH is offline   Reply With Quote
Yeti Score speed increase - Similar Threads
How can we increase Yeti ground clearance? npcaldwell Axial Yeti 26 08-14-2017 04:43 PM
Bomber Increase speed? 06yz250f Axial RR10 Bomber 25 03-16-2017 08:48 AM
LNC Seach for increase speed and good torque YNPpro Team Losi Comp Crawler 28 03-08-2013 07:10 AM
best way to increase wheel speed? 2004neonsrt4 Axial AX-10 Scorpion 10 05-10-2008 02:53 PM
