04-17-2018, 07:59 PM | #1 |
Rock Stacker Join Date: Jul 2015 Location: New Richmond
| Another Yeti Score build!
Well guys lost out on an SC10 SCT truck (going for more than I want to pay) SO made an offer on this Yeti Score RTR chassis on eBay for $215 shipped and got it! #racetruck haha Going to make it a light weight, decent handling race truck. Typical SCT wheel/tires, body, and a few upgrades! Bought decals for a Rob MacCachren Mopar truck with another Pro-Line Ram 2500 body. Hot Racing front sway bar Hot Racing 43/13 gears Traxxas turnbuckles for camber/steering Twin Hammers rear links Ditch the fuel cell (cut down aluminum links in place) Axial narrow 12mm hubs SSD servo arm SSD Yeti D60 centered housing Yeah Racing titanium steering link Reedy shorty 2s lipo Savox servo SV3/5700kv system from my other Yeti Traxxas black/blue 2.2/3.0 wheels Jconcepts Dirtwebs (golds) Few other things! |
04-17-2018, 08:07 PM | #2 |
Pebble Pounder Join Date: Oct 2015 Location: B.C.
| Re: Another Yeti Score build!
Looking forward to this one Rob Mac is one of my favourites.
04-17-2018, 08:13 PM | #3 |
Nice! Me too! My other truck sadly is to heavy for the SV3/5700kv SO I decided to save up and buy an 1/8 scale combo for it. So I'm donating the SV3/5700, and a few other parts from my other truck to build another ahaha Wanted to do a light weight race style truck out of one of these to see if it could hang with the likes of race style SCT's on a clay track haha. |
04-17-2018, 11:33 PM | #4 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
I doubt it, but it'll look cooler. |
04-18-2018, 05:29 PM | #5 |
That's ok I'm a crappy RC driver on a track anyway ahaha
04-19-2018, 02:26 AM | #6 | |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: Another Yeti Score build! Quote:
If you are still set on spending your money to run a yeti against SCTs, here's my comments: - dial out as much anti-squat as you can stand from the rear suspension. - unlock the rear diff - I have heard that the spider gears won't last long on the track, but will will reduce 'fishtailing' - use the stiffest blue-dot axial springs, and dampen well; you can run the suspension lower with less bottoming - the fuel cell is integral to the chassis cage stiffness - find out what tires work for your particular track, and get those. | |
04-19-2018, 04:20 PM | #7 | |
2. good idea! Will do that! (swap front dif for rear ahaha) 3. Noted 4. fuel cell is going to be replaced by aluminum threaded links 5. It's an indoor clay track almost blue groove - Jconcepts Dirt Webs golds are the plan | |
04-19-2018, 05:23 PM | #8 |
Said F it and ordered the parts! Once the chassis shows up the modding will begin! Going to try to mount the battery further in the chassis to lower the center of gravity a bit. Very little time left to wrench sadly as it gets nicer out my 1:1 will get all of my attention here! Parts! Axial narrow 12mm hubs Axial 7.5x80mm threaded links (making upper rear links) Hot Racing Twin Hammers lower links Hot Racing Yeti front sway bar Hot Racing Wraith rear sway bar (already have) Hot Racing 43/13 gear (already have) SSD D60 centered plastic axle housing (already have) SSD 25t servo horn Protek 5x8 bearings for steering rack Traxxas 3643 turnbuckles for camber/toe links Traxxas 2.2/3.0 split spoke blue/black wheels Pro-Line Ram 2500 body for a Slash Jconcepts Dirt Webs gold compound (indoor clay) Reedy shorty 2s lipo Power HD 13kg servo Castle 5700kv combo (already have) Robinson 15t/18t 32p pinions (already have) Yeah Racing titanium steering link (3x40mm) Yeah Racing aluminum wheel nuts Probably a few other little things I'm forgetting.. but this truck will not get much to keep it as light as possible. Will be a fun truck! - Got banned from Facebook for 7 days so pics will come when the ban is lifted (week or so, but will be waiting that long for parts ahaha) |
04-29-2018, 08:24 PM | #9 |
Big update - I decided to abandon the Traxxas Slash 2wd trans, and just put it back together. here is what I've done since this is a RTR truck - Cut out 2 speed servo pocket Cut out radio box Installed 14x70mm blue extra firm front springs (Thinking 60wt in front and 40wt in rear) Installed machined 38/13 gears from my kit Installed front universal axles from my kit Installed the gear differentials from my kit and RTR 4wd restored Installed the SSD D60 Yeti axle from my kit 56/18 gearing Traxxas turnbuckles for camber/tie rods Axial narrow 12mm hubs Yeah Racing aluminum wheel nuts Yeah Racing 3x40mm steering turnbuckles Installed Yeti buggy rear posts in place of fuel cell Hot Racing lower rear trailing arms Hot Racing front sway bar Hot Racing Wraith rear sway bar Axial 7.5x75mm rear upper links SSD 25t servo arm Power HD 180oz steering servo Same Castle 5700kv from my other truck Reedy shorty 2s 4200 lipo Plans are changing again for this truck as well! - Tbone Racing skid plate Hot Racing 115mm limit straps AE 40wt shock oil AE 80K dif oil AE battery foam kit Racers Edge body foam spacer kit New SSD rods ends Lunsford titanium turnbuckles for tie rod, camber, rear upper links, servo link, rear sway bar links Last edited by Zac_F71; 04-29-2018 at 08:28 PM. |
Another Yeti Score build! - Similar Threads | ||||
Scale Yeti Score kit build | Zac_F71 | Axial Yeti | 15 | 12-21-2018 11:51 AM |
Yeti score build | OhioSuperSport | Axial Yeti | 2 | 04-04-2018 10:06 PM |
New YETI SCORE Build | Malazan | Axial Yeti | 23 | 01-20-2017 03:10 PM |
Yeti Score Truck to Yeti Conversion | jeb. | Axial Yeti | 2 | 07-25-2016 05:58 PM |
Axial Yeti Score Kit Build | EDDIE THE YETI | Axial Yeti | 2 | 05-25-2016 06:56 PM |
