06-09-2018, 07:31 PM | #1 |
Newbie Join Date: Sep 2017 Location: California
| Yeti Which Mamba esc?
I have a yeti kit with no electritronics Who’s exc should I get I want cc Mamba x Mamba monster x or Mamba monster 2 |
06-09-2018, 09:04 PM | #2 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
| Re: Yeti Which Mamba esc?
Mamba X; big enough for the motors typically used with the yeti's weight and gearing (2800-3500kv) and the aux wire allows for toggling or adjusting parameters on the ESC on the fly. For example, you can connect the ESC's aux wire and the shift servo to the same radio channel, so that the drag brake turns on with the shift into low gear. |
06-09-2018, 11:32 PM | #3 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
The Monster X also uses the aux wire and can be had cheaper than the Mamba X, unless you are buying a combo. If you have the space then I would suggest using the Monster X with its better overhead. Things don't break because they are under stressed. Sent from my LG-H870DS using Tapatalk |
06-10-2018, 02:26 AM | #4 |
RCC Addict Join Date: Jun 2016 Location: Germany
Both X ESC are suitable. Cause a Yeti could get heavy. I would go with the Monster X, which is also cheaper than the Mamba X at some stores. And i like to have some buffer in the power drain. My personal rules for electric in my rc continues current A >= peak A: Lipo >= esc >= motor; esc/bec >= servo for the cable diameters the same lipo >= ESC >= motor so no stress in these sequences. Send by my Pixel 2 XL with Tapatalk Last edited by magic_yeti; 06-10-2018 at 04:47 AM. |
06-10-2018, 08:36 AM | #5 |
the momba monster 2 dose not have a sensor port but has good senserless start up
06-11-2018, 12:57 AM | #6 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
I run the Mamba X on a 10 lbs Yeti, no problems. Temperatures outside have been mild though. I think the Monster X is a fair bit larger, I would have a problem fitting it in.
06-11-2018, 09:21 AM | #7 |
Rock Crawler Join Date: Mar 2012 Location: UK
| Re: Yeti Which Mamba esc? |
06-11-2018, 04:29 PM | #8 |
Rock Crawler Join Date: Nov 2014 Location: Dells
The monsterX is mostly the same size and shape as the mambaX.
06-11-2018, 06:55 PM | #9 |
| Re: Yeti Which Mamba esc? Mamba X on left, Mamba Monster X on right - another thing that makes the Monster harder to cram in a small space is that is has the thicker wires coming out of both sides of the ESC, whereas the Mamba X has all 5 clustered on the one end... |
06-11-2018, 07:22 PM | #10 | |
| Re: Yeti Which Mamba esc? Quote:
06-11-2018, 11:08 PM | #11 | |
Mamba Firmware V2.02 It seems that usually it is in the setting of the endpoints, that you don't have them set far enough apart. | |
06-19-2018, 03:48 PM | #12 |
Rock Crawler Join Date: Mar 2017 Location: Rubicon Trail
I opted for the Mamba X SCT. Seems to work well and the sensors setup is really nice as opposed to my velenion. Sent from my iPhone using Tapatalk |
07-11-2018, 07:58 AM | #13 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
I went with the Monster X but the Mamba X would probably be fine as well.
Yeti Which Mamba esc? - Similar Threads | ||||
Yeti and the Mamba X?? | jason1973 | Axial Yeti | 14 | 08-07-2017 05:16 PM |
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
