Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Size of motor shaft?
Old 12-03-2018, 09:14 PM   #1
Question Size of motor shaft?
I’m in my final buying process for my yeti to get the motor. Why size motor shaft does every one use? I’m going to buy the 3800kv castle creations motor.
Steelone232 is offline   Reply With Quote
Old 12-03-2018, 09:20 PM   #2
Default Re: Size of motor shaft?
The yeti comes with a 5mm Pinion. You can use either a 3.17mm or 5mm. Just make sure you have a suitable Pinion. Personally I'd stock with a 5mm shaft if you can.
Sent from my LG-H870DS using Tapatalk
Stray is offline   Reply With Quote
Old 12-03-2018, 09:38 PM   #3
Thanks for the info!
Old 12-03-2018, 09:45 PM   #4
At least my yeti kit came with a 5mm Pinion. I assume the rtr does too. Best advice, get a motor, and a 32p Pinion to suit the motor you buy
Old 12-03-2018, 10:58 PM   #5
I would go with the 5mm shaft, that's what i did. I had the unsensored 1410 3800kv 5mm, great motor. But it was unsensored, so i changed to a HH 540R also using a 5mm shaft. Both great motors for the yeti. I power them with 3S lipos.
magic_yeti is offline   Reply With Quote
Size of motor shaft? - Similar Threads
drive shaft size? Crutch RC4WD Trail Finder 2 7 07-16-2014 10:30 AM
540 shaft size bahogtubig Redcat Crawlers 1 01-27-2011 07:57 PM
Output shaft size? Rudukai13 Axial AX-10 Scorpion 2 10-04-2007 03:53 PM
Shaft size on the GD600? jwrape General Crawlers 29 10-19-2006 06:28 AM
