Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: Spur/Pinion for stock 1/10 RTR setup on 3s
Old 12-16-2018, 04:18 PM   #1
Default Spur/Pinion for stock 1/10 RTR setup on 3s
So, I picked up a rather beat up Yeti missing the Spur gear so before I order a replacement any recommendations for a 3s setup? I had a yeti RTR before and remember the motor getting hot on 3s.
This will be for mobbing around on trails and open areas, I don't beat the hell out of my cars. I have a bomber among others for crawling as well. This might see minor crawling but nothing crazy. So I'd rather see a little more speed out of it. No extra mods to it and plan to keep it that way for a while
Willing to change the spur and pinion.
Thanks for the comments.
(stock is 32/64, pinion is 32/16)
Mayday! is offline   Reply With Quote
Old 12-16-2018, 04:45 PM   #2
Default Re: Spur/Pinion for stock 1/10 RTR setup on 3s
I would go down 2t to a 14t pinion with 64 spur, this will take stress from ESC and motor on 3s and it will be still fast. The RTR combo run on it's limit on 3s.
Gesendet von meinem Pixel 2 XL mit Tapatalk
magic_yeti is offline   Reply With Quote
Old 12-16-2018, 06:40 PM   #3
What Magic said... if you’re gonna keep all else stock RTR brother.
Nastyman211 is offline   Reply With Quote
Spur/Pinion for stock 1/10 RTR setup on 3s - Similar Threads
Yeti pinion gear sizing with stock spur? norco kid Axial Yeti 5 06-29-2015 06:39 PM
80 Spur, 2S, Axial Stock 55T Motor.. what pinion? StefanM Axial AX-10 Scorpion 8 11-05-2011 04:48 PM
need help properly mesh pinion and spur also suggestions on brushless setup bro_die Axial SCX-10 0 02-22-2011 04:55 AM
Stock TLT pinion and spur. FORD84 Newbie General 2 07-11-2007 03:05 PM
What is the bigest Spur and smallest pinion on stock TF jwrape Kyosho Crawlers 4 10-25-2006 12:12 PM
