Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial Yeti
Thread: New Christmas Yeti stopped working...help?!?!
Old 12-25-2018, 10:44 AM   #1
Default New Christmas Yeti stopped working...help?!?!
I just my son a Yeti and was so excited. We drove it in our grassy backyard for about an hour then this happened...please help!
https://youtu.be/CBz56otcYyk
cincysock is offline   Reply With Quote
Old 12-25-2018, 10:56 AM   #2
Default Re: New Christmas Yeti stopped working...help?!?!
Open up the cover for pinion and spur gear. Sounds like they are not meshed properly. Easy fix. Awesome gift by the way!!
Nastyman211 is offline   Reply With Quote
Old 12-25-2018, 11:21 AM   #3
Good rule of thumb, OP is to slide a strip of notebook paper between the pinion and spur when setting the mesh. You want them to make solid contact but not be overly tight.
high plains drifter is offline   Reply With Quote
Old 12-25-2018, 01:38 PM   #4
Sweet present!
As mentioned above, removing the gear cover should reveal the issue.
It’ll most likely either be the gear mesh, or a loose pinion gear.
If it ends up being a loose pinion gear (the small metal gear on the motor shaft), you’ll just want to add a small drop of blue loctite to the grub screw that holds it in place.
Davey is offline   Reply With Quote
New Christmas Yeti stopped working...help?!?! - Similar Threads
It's stopped working gtione Axial SCX-10 26 07-25-2014 04:14 PM
Motor stopped working Threesheets Losi Mini-Rock Crawler 13 05-26-2013 09:54 PM
Stopped working, AGAIN *xj-man* Losi Mini-Rock Crawler 14 04-23-2009 08:56 PM
Stopped Working... *xj-man* Losi Mini-Rock Crawler 8 04-09-2009 04:55 PM
Stopped Working!?!?!?!? Z71HULK General Crawlers 8 01-16-2006 10:20 AM
