07-07-2019, 11:03 PM | #1 |
Newbie Join Date: Sep 2017 Location: California
| Rear axle question?
So my 1/10 yeti kit is pretty new, with 3800 castle creation motor and speed control on it. Every time I run it I here this clicking noise coming from the back end. So I took the rear diff apart and did find anything bad. Could the back two gears in the back diff be not set right. Has anyone else had this problem. Thanks for reading
07-08-2019, 11:25 AM | #2 |
RCC Addict Join Date: Jun 2016 Location: Germany
| Re: Rear axle question?
Maybe there is some play in the gears. Check if your drive shaft is moving in and out. If so you have to use some shims to eliminate the play, so the gears can't slip. If this is your issue.
Rear axle question? - Similar Threads | ||||
Ssd rear axle question | Shorty123 | Axial Yeti | 12 | 03-09-2017 08:51 PM |
Rear axle question. | bryco13 | Axial Yeti | 6 | 09-26-2014 07:27 PM |
ax10 rear axle question | bro_die | Axial AX-10 Scorpion | 6 | 12-13-2010 05:19 AM |
TLT Rear Axle Question | procraft98 | Newbie General | 4 | 05-01-2008 07:45 PM |
Solid rear axle question | Frosty619 | Chit Chat | 7 | 09-09-2006 05:01 PM |
