03-21-2020, 03:13 PM | #1 |
Newbie Join Date: Feb 2020 Location: NYC
| Building a new Yeti Score Trophy Truck kit..any tips?
Finally located a new kit and going to start the build soon. Are there any must have hop-ups or issues I should address right away? I was thinking about adding all the Vanquish Products steering rack/bellcrank/posts since steering slop seems to be a big issue. I am also debating whether to do Hobbywing SCT Pro or Mamba X (or even MMX) ESC with sensored motor. I plan on eventually getting all the aluminum bits so think I’m better off with a ~3600kv on 3s or 4300kv on 2S? Any insight greatly appreciated! Sent from my iPad using Tapatalk |
03-23-2020, 09:59 AM | #2 |
| Re: Building a new Yeti Score Trophy Truck kit..any tips?
Going with Monster X and 550 sized motor. I really would appreciate guidance on the hop ups - especially ones that should be addressed sooner rather than later. Is there a need to update rear axle before bending the stock one? I don’t really dig the look of the SSD wide centered aluminum axle. It just doesn’t look scale to me — is the Vanquish axle still handicapped because of Wraith width or a lot of the initial issues get sorted? The existing rear axle threads are 5-6 years old so hard to tell if they are still relevant. I kind of like the HD D60 nylon SSD axle, looks much more realistic than their aluminum offering |
04-07-2020, 05:39 AM | #3 |
Newbie Join Date: Feb 2016 Location: Poland
Drive shaft is a must - you will break the plastic one with that power. Also be wary of front A-arms - either You will break one or bend the pin holding it to the chassis. I broke front skid plate and damaged the chassis a little (literally sliced it in half on a rock while landing) so i would beef that up also. I would also invest in some radiator for the motor since air flow inside is meh unless You "tune" it up a little. cheers! |
04-08-2020, 12:12 PM | #4 |
Newbie Join Date: Oct 2015 Location: Norwalk, CA
Front A-arms and pins is a must to upgrade, you can buy the sleeved arms or make your own to prevent bending the pins
04-08-2020, 02:57 PM | #5 |
Rock Crawler Join Date: Mar 2016 Location: Murphy
On both my Yeti & Trophy Truck I did the front a-arm hinge mod. Here how I did mine |
04-08-2020, 05:00 PM | #6 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Look at Metal Concepts for your rear axle, links, a arms......... Axle is a scale Tube Works piece, having the rear link mounts off the bottom the axle, not the front, as they are supposed to be in this application, a TT. Most every quality scratch built TT runs Mike's stuff. Beef it up a little bit, the heavier truck works better than a light one unless you plan on sending it like the Laughlin leap at the Parker BITD race. Get your shocks tuned correctly and they are an amazing rig to watch go.
07-15-2020, 03:46 PM | #7 |
Should I stay with 2.2/3.0 Short Course or switch to 2.2 or 1.9 wheels? I was debating getting either Mickey Thompson Classic locks or Raceline Monster wheels from RC4WD. I noticed people also use 1.9 tires on 2.2 wheels but now 1.9" wheels seem most popular. I intend to do some trail runs / light crawling but still want to be able to go fast on hard packed terrain. For tires i'm thinking Hyrax or PL BFGoodrich K02 so I'll have some ground clearance. I am going to use Hobbywing XR8 SCT Pro w/ 3600kv on 3S (stock 17t pinion) Since this is my first "scale" truck I would prefer to run beadlocks so I can play around with tire/foam options and have that bling |
07-16-2020, 09:32 PM | #8 |
Or should I just throw in crawler innovations SC foams with stock tires glued on stock wheels. :/ I know stock foams are useless. Kinda want aluminum wheels just wonder if 1.9 tire better for trail Sent from my iPad using Tapatalk |
07-20-2020, 12:38 PM | #9 |
You have to pick your poison, if you will. Do note, that the stock wheel/tire combo (5) is worth about $70, and are highly sought after. Soft foams for trail running will be less than stellar hauling the mail (sidewall roll), which is why the 1.9 stretched onto a 2.2 was popular in the scratch build community. I have 5 or 6 sets of the SCORE wheel/tire sets, they go on every go fast scratch build because they work and are durable even with a glue on bead.
07-22-2020, 07:53 PM | #10 | |
| Re: Building a new Yeti Score Trophy Truck kit..any tips? Quote:
This makes a ton of sense now that you mention it. I am going to stick with 2.2/3.0 & ordered some Chanquish wheels to test prior to making the commitment Sent from my iPhone using Tapatalk | |
07-23-2020, 08:02 PM | #11 |
Quarry Creeper Join Date: Dec 2016 Location: Orange County
Super happy with my Vanquish KMC XD series wheels and Voodoo U4 tires. Check out “from the tub up thread” |
07-26-2020, 11:18 AM | #12 | |
Yea those look amazing but I want to run Proline Raptor body so prob won’t be able to fit 5.5” tires in wheel well. I’m sure I’ll convert to RR setup one day Sent from my iPhone using Tapatalk | |
08-02-2020, 12:42 PM | #13 |
| Re: Building a new Yeti Score Trophy Truck kit..any tips? So I ended up finding a great deal on VP KMC XD229 Machete 2.2 wheels. Going to try out some 1.9 XL sized tires & CI foams. This way can figure out whether these bridge the gap btw 2.2/3.0 SC and 1.9 tires
08-10-2020, 07:11 PM | #14 |
Pebble Pounder Join Date: Jan 2017 Location: Maine
The SSD Wide Diamond rear axle is the way to go in my opinion particularly now that it appears that Vanquish has ceased production of anything that does not fit their VS4-10. I like the MIP rear drive shaft too. Those were the first things I replaced on my Yeti. I'm running a Monster X and a 3500 kv Puller Pro XL. I'm running Vanquish 2.2 KMC Bully wheels and Pro-Line 1.9 B.F.G. Mud Terrain T/A tires with Crawler Innovations Deuce's Wild Single Stage 1.9 foams stretched onto them on a Losi Baja Rey that is also running a Monster X and a Holmes 4100 kv Puller Pro R. They work well so far. Last edited by Rumpelhardt; 08-10-2020 at 07:23 PM. |
08-11-2020, 04:21 PM | #15 |
Quarry Creeper Join Date: Feb 2007 Location: Lleida
Hpi Sprint bevel gears for front diff RPM A arms SSD wide rear axle MIP driveshaft Exotek main chassis Aluminium front diff cup Proline Powerstroke shocks Traxxas rod ends GPM aluminium hubs |
08-11-2020, 07:13 PM | #16 | |
I agree, the SSD wide diamond axle is the best bang for $$$ but I wanted something a little more scale (after all that’s what attracted me to Solid Rear axle trophy truck). I ended up piecing together a Currie centered RockJock70 rear axle from VP website. Let see if I live to regret that decision. After I got the Currie F9 front bulkhead I really wanted an F9 rear axle but seemed impossible to find & as you said not in production Sent from my iPad using Tapatalk | |
08-29-2020, 05:59 AM | #17 |
The Wide Diamond axle is a pretty good approximation of a fabricated 9" Ford axle housing. They are used on quite a few Trophy trucks.
Building a new Yeti Score Trophy Truck kit..any tips? - Similar Threads | ||||
Yeti SCORE Trophy Truck Kit $80 Off! | RPP Hobby | RPP Hobby | 0 | 03-09-2018 11:47 AM |
Axial Racing Yeti SCORE Trophy Truck Kit Week Long Sale! | RPP Hobby | RPP Hobby | 0 | 01-29-2018 10:39 AM |
Yeti SCORE Trophy Truck IN STOCK! | RPP Hobby | RPP Hobby | 0 | 11-13-2015 11:33 AM |
