Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Custom T-case
Old 10-11-2008, 11:58 AM   #1
CadToChrome's Avatar
Default Custom T-case
This one's in the beginning stages
1:1 ratio
aproxximate size 1"x 1.25" x2"
CadToChrome is offline   Reply With Quote
Old 10-11-2008, 12:38 PM   #2
[HOONIGAN]
Wrecker's Avatar
Dang that looks sexy!
Wrecker is offline   Reply With Quote
Old 10-11-2008, 05:20 PM   #3
~The Scale Shop~
STANG KILLA SS's Avatar
its gonna be a t-case showdown! thats 4 on RCC now.
Old 10-11-2008, 05:30 PM   #4
666
666's Avatar
A shiftable one would b the shiznit, 2wd, 4wd, low, and high range.
666 is offline   Reply With Quote
Old 10-11-2008, 06:57 PM   #5
BigSki's Avatar
even better would be one that has a neutral position for a PTO output to drive a mechanical winch. How bad ass would that be??
BigSki is offline   Reply With Quote
Old 10-11-2008, 06:59 PM   #6
666
666's Avatar
Really, really cool!
Old 10-12-2008, 03:26 PM   #7
2wd,4wd,high,low, disengage, and pto for winch!
keala is offline   Reply With Quote
Old 10-12-2008, 05:28 PM   #8
So..........
just what do you want?
do you want servor control on the shift or walk up maunal?
how mave radio channels do most of you have?
I was thinking a servo controled disk brake PTO combo off the rear of a t-case.
Talk to me ?
Old 10-12-2008, 05:43 PM   #9
I think a PTO would be really cool. I would like to see these things done as add ons so that you could choose to have front axle disconnect or a PTO of both.
I wouldn't worry about channel to much you can get pretty cheap heli style radios now so extra channels shouldn't be a problem.
Tupers is offline   Reply With Quote
Old 10-12-2008, 06:17 PM   #10
BigSki's Avatar
I'm guessing, just from a manufacturing stand point, that it would be very hard to make a side mounted PTO provision, like on the 1:1 NP205 T-cases. You would almost need a DIG type disengagment system to isolate any drive power from getting to the axles, but still be able to turn a PTO shaft that would power the winch.
Maybe a constantly engaged drive mechanism from a PTO output that could be engaged at the winch? That way, either a servo or a manual level could be used to engage the winch. Man, this could get interesting....
Old 10-12-2008, 10:46 PM   #11
hell, i would be really happy with 2wd,4wd,disengage(dig), high and low. that would be it man. with that set up, we could have wheel speed and low gearing for torque. if it's possible
Old 10-14-2008, 03:22 PM   #12
mfg update, soon to be tested and ready for production
The transfer case is for custom builds, its not a drop in fit in any existing model
1:1 ratio and only uses 2 gears so depending on which shaft is used as input it can be used to either have both shafts spinning in same direction or flip the rear axle and run in opposite directions eliminating torque twist.
Old 10-14-2008, 03:35 PM   #13
Shut up Dave
jetboat's Avatar
pricing?
jetboat is online now   Reply With Quote
Old 10-14-2008, 04:52 PM   #14
Perpetual Newbie
Cave Dave's Avatar
How bout the double low box like in my Toyota. A guy needs at least 3 shift levers coming out of the floor.
Cave Dave is offline   Reply With Quote
Old 10-14-2008, 04:59 PM   #15
Kamikaze's Avatar
Won't that just make it flex hard one way and not flex well the other?
Kamikaze is offline   Reply With Quote
Old 10-14-2008, 05:57 PM   #16
pricing is not locked in yet but we are guesstimating at $80. or maybe less
depends on how many you guys order
the more you order, the less they sell for
Old 10-14-2008, 06:23 PM   #17
Upgrayedd
ctrwannabe's Avatar
@ that price i know id want one
ctrwannabe is online now   Reply With Quote
Old 10-14-2008, 06:46 PM   #18
be carfull what you wish for
I have only just begun to offer new products to you
I'll be updating my 1.9 scale lockout hub set thread very soon
(yes a complete front and rear set with installation tool)
perhaps tomorrow
Old 10-14-2008, 10:44 PM   #19
Throwing Grenades
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Unless you are using TLT's that is a pretty poor design. With Axials if you flip them you don't have a good way to do an upper link mount. Unless you have another idea.....
Harley is offline   Reply With Quote
Old 10-15-2008, 07:32 AM   #20
Fipping the axle is not a requirement, It's an Option. We are attempting to add more functional ability to our product. It may take a little thought to make it work for your aplication, but the function is there.
Maybe cut the servo mounts off the casing and flip the axle and use a couple of spacers to mount the centre link bracket ,you can run a flipped Axial rear axle.
I'm Thinking TLT axles, High Lift axles can be flipped, I think original Bruiser axles can be flipped, the RC4WD Ultimate axle can be flipped.
Remember, you dont have to run a flipped axle with this Tcase.
You may edit your posts
