Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: NEW! CKRC Crawlers Berg Rear Axle Lock Out kits!!!
Old 01-16-2009, 05:44 PM   #1
KING BLING's Avatar
Default NEW! CKRC Crawlers Berg Rear Axle Lock Out kits!!!
CKRC's new lockouts were designed with top winning performance in mind. Our new lockouts incorporate a SOLID 5mm hardened rear axle shaft to eliminate the common breakage of the factory dog bone and stub design. These new shafts incorporated with our HD low profile aluminum housing is absolutely the strongest set up you can buy.
Includes:
2-Aluminum Lockout housings
1-Hardened short shaft
1-Hardened long shaft
4-3x6mm button heads
For those with fabrication skillZ. This new rear kit even makes it possible to narrow your rear track width by 1".
We are shipping these to Rccrawler.com members for only $49.99. Shipping will be covered to the lower 48 states only. Paypal to ckrawler@sbcglobal.net
if you are from outside the lower 48 or would like to purchase our new lockouts with some of our other Berg upgrades. You can get them here:
http://www.ckrccrawlers.com/shop/ind...oducts_id=1636
l
KING BLING is offline   Reply With Quote
Old 01-16-2009, 06:27 PM   #2
I'm Dracula, Bitch.
JeremyH's Avatar
Damn, those are nice!
Great work!
JeremyH is online now   Reply With Quote
Old 01-16-2009, 06:31 PM   #3
TEAM RCC
bcrofts's Avatar
looks pimp looks like i need to get a pair
bcrofts is offline   Reply With Quote
Old 01-16-2009, 08:28 PM   #4
Tech Addict
frdtrkguy's Avatar
Those turned out really clean
frdtrkguy is offline   Reply With Quote
Old 01-16-2009, 08:32 PM   #5
SAWEEETT! I'll stop by the shop and pick up a set
saniel68 is offline   Reply With Quote
Old 01-16-2009, 11:23 PM   #6
Mr. Series Champ!!!!
finishline's Avatar
any HR axle lockouts on the way. tired of changing out rear axle shafts
finishline is offline   Reply With Quote
Old 01-16-2009, 11:46 PM   #7
I play with TOY TRUCKS
Rpp Hobby's Avatar
They look good Jake
Rpp Hobby is offline   Reply With Quote
Old 01-17-2009, 04:22 AM   #8
SMR4RUNNER's Avatar
Them are beefcake axle shafts Jake!
SMR4RUNNER is offline   Reply With Quote
Old 01-17-2009, 07:29 AM   #9
thats awsome, too bad i dont have the machinery to turn down those Cs cleanly
just curious, how much machining does it take to get those on? a HOW-TO maybe?
wojin is offline   Reply With Quote
Old 01-17-2009, 08:23 AM   #10
Money posted to ckrawler@sbcglobal.net for a set of those fine looking lockouts.
Carl
quickster47 is offline   Reply With Quote
Old 01-17-2009, 10:50 AM   #11
Keep Crawling in Crawling
Cruzin Illusion's Avatar
Money sent via paypal.
Thanks
EDIT:
My brother just bought them off CKRC's website $48.50 shipped:-(
Cruzin Illusion is offline   Reply With Quote
Old 01-17-2009, 12:06 PM   #12
jeepcj578's Avatar
look here
http://www.ckrccrawlers.com/shop/ind...oducts_id=1637
jeepcj578 is offline   Reply With Quote
Old 01-17-2009, 12:08 PM   #13
jeepcj578's Avatar
will the shafts be avlabe by them selves so people can keep a spare set in there box?
Old 01-17-2009, 12:21 PM   #14
KING BLING's Avatar
Thanks guys. The cutting of the rear housing is pretty simple and it doesn't have to be perfect or perfectly straight. We are not going to be offering replacement shafts. I dont see any way that someone could break these.
No matter how much motor you have or how bad you drive, They are beefy! The shafts were put into a vise and we twisted on them with vise grips as hard as we could to see when they would break. We also did the same think to the axial, and rc4wd rear straight axles, and after 3 attempts with them they broke. Our shafts didnt twist in the slightest and then we beat on them with a hammer for 10 minutes trying to break them.
Old 01-17-2009, 06:29 PM   #15
Just picked up mine!!! Checked out JACKSMASH's rig. @ CKRC. Very clean install.
Old 01-17-2009, 08:24 PM   #16
XJ Farmer's Avatar
I've gots to get me some Great idea!
Later
Farmer
XJ Farmer is online now   Reply With Quote
Old 01-18-2009, 05:44 PM   #17
i was thinking there might be more to the install, pretty simple though. if i end up breaking a shaft(likely) or having any problems with the FUBARs(not likely) i will definatly be picking these up
Old 01-20-2009, 01:23 PM   #18
KING BLING's Avatar
Has any one gotten there kits yet? What do you think?
Old 01-24-2009, 09:45 AM   #19
I received the kit two days ago and installed it. I followed the directions from the website down to the letter. The problems I see that some will have. If you cut the inner knuckles off where the directions tell you to it will not leave you enough material to drill and tap at the location where the holes are on the lockouts. I had to drill new holes 90 degrees from the original holes inboard. I then used those holes as a guide to mark the axle tubes and drilled and tapped the axle tubes at the more inboard locattion. The second problem I had was the long shaft. The machined portion that the bearing slides over was to big. I had to stick the axle shaft in a drill, run the drill, and use some 220 grit sand paper to take the diameter down just a hair. The short side was perfect.
I have another set that I will be installing on the berg I am building for my wife. I will not cut the the complete in knuckle off but just cut the knuckle ears off and file down the remaining material till it is smooth and the lockouts fit over the ends. That should aleveate the problem of moving the mounting holes inboard.
The long side shaft problem I would fix the same way as I did for my brothers.
Also the bearings that you remove from the knuckles and install into the end of the lockouts have a little slop when installed in the lockout ends. I would have like to see them fit a hair tighter.
Hope this helps.
I will be installing my wifes tonight or tomorrow and let you know how that went. Overall a pretty easy install.
Old 01-24-2009, 02:47 PM   #20
Installed mine the other day. I cut the ears off of the C's and had plenty of room to drill and tap the axle housing. Overall very strait forward install.
You may edit your posts
