| | #1 |
| RCC Addict ![]() Join Date: Dec 2006 Location: RENO
| Its all ready here. The new "ready to Crawl" from axial racing. CKRC has them on sale for only $???.00 You can get one here: http://www.ckrccrawlers.com/shop/ind...oducts_id=1929 AX10 SCORPION RTC (READY-TO-CRAWL) Based upon the award winning AX10 Scorpion - KIT! FEATURES Complete Ready-to-Crawl (RTC) out of the box ALL NEW SHOCKS 4 Wheel Drive (4WD) Mount a standard stick pack to get up and running quickly, or use the included upper link plate to mount smaller batteries lower in the chassis for improved crawling performance 55T electric motor: tear up the terrain in-door or out-doors. Easy Operation: no tuning, no fuel, no loud exhaust noise. Just plugn'go! 14T pinion paired with an 87T spur gear gives you a decent amount of wheel speed and great low-end torque. True beadlocks: no messy glue Hi-quality composite plastic and metals Durable (ESC) Electronic Speed Controller: Hi-quality durable forward and reverse speed controller. Hi-torque Metal Gear Servo help hold your line when rock crawling Solid rear axle lockouts improve ground clearance when crawling Slipper clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain. Aluminum chassis plates with a molded nylon skid plate provide a solid and rigid chassis Ultra compact and lightweight transmission Fully locked differentials for more traction when rock climbing! Full ball bearings Overall gear ratio range from 15:1 to 74:1 Transmission: 2.6:1; center mounted Differentials: front - gear differential; rear - locked (spool) Transmission: single-speed Tires: Pro-Line Hammersฎ with Pro-Lineฎ Memory Foams Wheels: Axial 2.2 8 hole beadlocks (satin chrome) Suspension: 3 Link Drive Shafts: universal front and rear 72-103mm shock length, helps lower the center of gravity Threaded shock body for easier pre-load adjustments 3.5mm shock shaft reduces lateral movement Cartridge style bottom helps reduce lateral movement while providing a better steal for less leakage Silicone diaphragm provides more consistent feel and better seal to prevent leakage Silicone bushing in cap holds shock in place while allowing freedom of movement to prevent binding and prevents the shock cap from popping off CHASSIS Wheelbase: 316mm~332mm (12.4~13) Width: 254mm (10) Height: 156mm (6.125) Weight: 1588g (3.5 lbs) Articulation: 70ฐ Ground Clearance: 68mm (2.7) ELECTRONICS Radio: 2 Channel Servos: 1 hi-torque metal gear (standard size) Forward/Reverse ESC Motor: 55T 540/550 Size ![]() |
| Sponsored Links | |
| Thread Tools | |
| Display Modes | |
