| | #1 |
| RCC Addict ![]() Join Date: Apr 2009 Location: Krawler Lab
| Krawler Hobbies Delrin Steering Link Kit Designed to work with ALL of Axial's crawlers. It is a direct replacement for the steering links on the RTR, RTC, ARTR, and AX10 Kit. It replaces the weak plastic steering links on the RTR and RTC crawlers and the aluminum on the ARTR and AX10 Kit. Constructed out of 5/16" delrin rod, it glides over rocks 100 times easier than aluminum and stands up to the abuse that the RTR plastic links can not take!! There are heavy duty Revo rods ends on each end of the links. They can take what you dish out!! Notice that our kits are much thicker than the stock plastic links. Also, the round delrin, glides of the rocks much easier that then stock links. This allows for less hangups on the steering links. Notice, we took GC into consideration too!! Our kit comes with button head screws. Much closer to the steering knuckles than the larger stock hardware. Plus, our kit comes with the aluminum spacer to allow for proper link alignment!! All of our hardware is stainless steel so you know it will last as long as your crawler. Kits will come in either white delrin or black delrin. The white delrin can be dyed a custom color to match your rig!! Pricing: Delrin Link Kit: $12.99 Shipping: $5.00 This is for the lower 48 states. All other PM for information. Last edited by KrawlOff-Road.com; 06-24-2009 at 09:23 PM. |
| Sponsored Links | |
| | #2 |
| | #3 |
| Pebble Pounder Join Date: Jul 2008 Location: fremont
| i've got an over-the axle 4-link plate. Battery is also mounted on axle. Will you do servo-to knuckle link for my set-up? |
| | #4 |
| Sure! PM sent.-Jason |
| | #5 |
| We are now offering this setup with the longer upper link for the same price!! Now, when you order, you can pick which top link you would like. Longer or shorter side!! -Jason |
| Thread Tools | |
| Display Modes | |
