Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: RcBros Losi Comp Crawler LCG Servo Mount
Old 07-16-2009, 09:12 PM   #1
Live,Eat,sleep RC
RcBro's Avatar
Default RcBros Losi Comp Crawler LCG Servo Mount
One of the key's in crawling is keeping your center of gravity lowest to the ground. Sometimes dropping something as small as 1/4" can mean the difference between making the line and rolling on your lid.
We've created a mount out of 1/8" T6 6061 Aluminum weighing in at 5 grams lowering your steering servo a 1/4" and dropping some of that precious weight lower to the ground.
In order for this mount to work you will need to file down the rear standoff to equal height of the front standoffs. This can be down quickly with a dremel or file.
Each mount includes two 3x8mm that self tap into the stock servo mounts coming up from the bottom and 1 4-40 1/2" and 2 4-40 3/8" for securing the mount securely to the axle.
Full Kit:
1 Mount
2 3x8mm Button Head Screws
1 4-40 1/2" Flat Screw
2 4-40 3/8" Flat Screw
Price: $10.00
RcBro is offline   Reply With Quote
Old 03-01-2011, 12:16 AM   #2
Live,Eat,sleep RC
RcBro's Avatar
Been sometime since we've bumped this post, wanted to let this thread back to the stop for some of the new customers on the forums!
Old 04-06-2011, 09:26 PM   #3
Live,Eat,sleep RC
RcBro's Avatar
Been getting some interest in these guys again, just wanted to bump it up for those who haven't seen it!
You may edit your posts
