| | #1 |
| felsenfest ![]() Join Date: Jan 2005 Location: Germany north
| the TLT felsenfest knuckles are ready now 3 Versions are available the TLT V5 , zero Ackermann ![]() TLT V5.1 , zero Ackermann and double arm for tierod infront or bta ![]() TLT V6.1 , Ackermann for bta and double arm for tierod infront ![]() the center parts are made of 7075 aluminium the plates are made of stainless steel screws are black button head price will be 40€ per pair V5 and 44€ per pair V5.1 and V6.1 +10€ shipping (up to 400 gramm) just send your payment in € (EURO) to felsenfest@sarrazin-mv.de members within the EU need to add the german VAT 19% |
| Sponsored Links | |
| | #2 |
| I wanna be Dave Join Date: Jan 2006 Location: Henderson/Las Vegas, NV
| so im assuming the 6.1s will provide correct ackerman where the inside tires steers further than the outer? |
| | #3 |
| | #4 |
| some build in pics Pete´s Exocaged LR Ninety |
| | #5 |
| greasypete´s six shoota with felsenfest TLT V5 knuckles ![]() ![]() ![]() ![]() thanks for the pics Pete and goodluck for the castrop comp |
| | #6 |
| Rock Crawler Join Date: Oct 2006 Location: Germany
| Thanks for that great product, christian. I was able to get a bit more steering, while grinding a bit of the axle-C´s off. Thats now the limiting factor: steering arm hitting the C-arms. BTW: The steering-rod (connecting the knuckles) is now from an axial rig. You can use your origianl axial steering rod (if you have one in your sparebox) with the felsenfest knuckles on a TLT rig Lucky on that, because so the conversion was done in 1/2 an hour. Also, I used the inner position for the servolink, so I get the most travel out of my high-torque servo. Pete |
| | #7 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| | #8 |
| Pebble Pounder ![]() Join Date: Jul 2008 Location: Kansas City
| Are these still available? I am building a rock racer with TLT's and these would be perfect. |
| | #9 |
| Rock Crawler ![]() Join Date: Nov 2006 Location: bonney lake
| any chance you will make cvds for the tlt? |
| | #10 |
| | #11 |
| Newbie Join Date: May 2011 Location: Finland
| Thread Tools | |
| Display Modes | |
