09-27-2009, 11:15 PM | #21 |
| I would not suggest this with the X-Trail. Since the X-trail is a full length chassis and this kit offsets the servo you will likely run into clearance issues between the frame and servo. The only way to solve this would be to run a very high ride height which is not very scale.
10-06-2009, 01:00 PM | #22 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
Ive ran it on scale chassis' myself and have had mixed results. As Harley said, with allot of scale chassis' you end up with the chassis hitting the servo.
10-15-2009, 12:31 PM | #23 |
Newbie Join Date: Oct 2009 Location: mesa
| a123 cells
was thinking about using this kit and mounting the a123 cells up front this would probly take out the need to add some weight to the front tires and wheels.. just a thought i would like to know what you think
10-15-2009, 08:35 PM | #24 |
Quarry Creeper Join Date: Feb 2009 Location: Ukiah
What are the dimensions (length x width x height) of your a123 battery pack? -Jim Last edited by Gear Head RC; 10-15-2009 at 08:56 PM. |
11-09-2009, 06:52 PM | #26 |
RCC Addict Join Date: Feb 2006 Location: ccxc
can you mount a 4 link on it?
11-09-2009, 06:58 PM | #27 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
Yes, its a 4 link plate. Thats another reason I bought it vers the Axial's one coming out, there's is a 3 link.
11-10-2009, 09:54 AM | #28 |
hmm if it is a 4link i might have to get it
11-20-2009, 01:03 AM | #29 |
Rock Stacker Join Date: May 2009 Location: grand junction
i got one on the way will post pic when installed
11-20-2009, 11:42 PM | #30 | |
Newbie Join Date: Nov 2009 Location: Milwaukee, Wisconsin
12-31-2009, 01:13 AM | #31 |
| New pics
Here are some new pics of my BTA kit installed on my comp crawler. Enjoy! |
01-06-2010, 08:17 PM | #32 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
The older version that I have works very well with the VP high steer knuckle, so i am sure it will work just as well with the redesigned version and there is no need for the spacers when you use the HS knuckles and it also clears all of the shock/lower link screws.
01-15-2010, 11:24 PM | #33 |
Rock Stacker Join Date: Jan 2007 Location: Elk Grove
Will this BTA kit work with VP Zero ackerman knuckles?
01-16-2010, 12:09 AM | #34 |
| Unfortunately, it does not. Here is an up-to-date compatibility list: Recommended: Vanquish Products (VP) High Steer Knuckles ST Racing Concepts Aluminum Knuckles Hot Racing Aluminum Knuckles Axial Aluminum Knuckles Works, but not recommended: Stock plastic Axial knuckles Does not work with: ST Racing Concepts High Clearance Knuckles Vanquish Products (VP) High Steering Zero Ackermann Knuckles |
01-16-2010, 08:36 AM | #35 |
01-16-2010, 09:08 AM | #36 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
Most probably because they will flex way to much with the increased leverage from the spacer. BTW where can I get this kit apart from RPP? Corey doesn't ship to Greece. Thanks! |
01-16-2010, 09:12 AM | #37 |
01-16-2010, 06:18 PM | #38 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
What length link would i need to go from servo arm to tie-rod? I will be using VP High-steer knuckles
01-17-2010, 07:50 PM | #39 |
Newbie Join Date: Jan 2010 Location: palmerton
| bta
love the set up just got it
01-17-2010, 08:45 PM | #40 |
