09-08-2010, 05:57 PM | #41 |
Pebble Pounder Join Date: Mar 2008 Location: Amarillo
I'd actually think you'd have too much trouble with power/rpms since you wouldn't have the gear reduction normally present in the transmission.... try running something like an AX-10 tranny with motor attached, then go out of that to the GCM with a fast brushless setup and you'll rip just fine.... (I tried something similar with a castle 5700kv brushless directly into my AX10 with 2.2 flatirons on it and it was outrunning my savageXL and getting close to keeping up with my touring cars that were running the same motor....and could light all 4 tires at once....) |
09-11-2010, 03:16 PM | #42 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Great product! Order has been placed. |
09-15-2010, 04:40 PM | #43 |
Rock Stacker Join Date: Mar 2009 Location: lake odessa
the hardest part is mounting a trans on the wheely king unless u use the wheely king trans.. cause of the way the frame is.... but i guess the ax-10 and scx-10 trans are strong as hell... i have a scx10 with the hard gears in the trans and the axles with a 9t brushless motor 87/25 gearing and that thing ripped.. with the 2.2 mudslingers... but now it is a crawler with a 35t tekin brushed motor with fxr esc 2s lipo and i run 2.2 cut v-treads in the back and narrowed v-treads in the front with 81/25 gearing it is fast and has alot of grunt..... i will prolly run some sort of tranny somehow thanx for the info
10-27-2010, 02:35 PM | #44 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
just ordered one of these right now. looking forward to getting it!
11-30-2010, 07:37 PM | #45 |
Rock Crawler Join Date: Feb 2006 Location: Cutting Comms
Do you still offer the Starter Kit version? I cant find it on your website, only the Full Kit.
11-30-2010, 07:48 PM | #46 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
No, we don't. You could send email to GCM and get one though.
11-30-2010, 08:07 PM | #47 |
12-28-2010, 02:15 PM | #48 |
I sent a question via the website, but thought I'd ask here as well. Would it be possible to get a case that would accept gears of different sizes? I would like to use this to overdrive the front driveshaft and underdrive the rear. Thanks! |
12-28-2010, 07:23 PM | #49 |
There's certainly no real way to make a case with this size and still this variability. In order to use different gear sets a new case would be designed, it would have to be larger, and modular to accept new and changing gear mesh and shaft spacing, and likely it would be quite expensive and far less reliable. For over or under driving axle sets, I can only recommend doing that in the differential cases themselves using odd pinion/ring combinations. But anything is possible! |
10-11-2011, 07:43 AM | #50 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
Sweet looking transfer!! |
02-17-2012, 08:19 AM | #51 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
| Re: GCM Transfer Case
hey there, i am looking to get one of these if there is another run coming or something. i checked tcs, rpp, and they didnt have any in stock. can you let me know where i might be able to get one? paypal ready. |
02-17-2012, 09:58 AM | #52 | |
| Re: GCM Transfer Case Quote:
Thanks | |
02-22-2012, 08:07 PM | #53 |
Rock Crawler Join Date: Feb 2011 Location: Williston
ETA for gears? and I never did see any specs on the size of this case? height, length, width? L.R. edit: I did send an e-mail, if there is a waiting list I asked to be put on it. thanks! L.R. Last edited by LoneRanger; 02-23-2012 at 10:09 AM. |
02-23-2012, 02:34 PM | #54 |
Should be back in stock and shipping mid next week! Thanks
02-23-2012, 03:27 PM | #55 |
Just waiting to hear from y so I can order up! L.R. |
08-19-2012, 02:32 AM | #56 |
Quarry Creeper Join Date: Dec 2010 Location: Anaheim
are you still making transfer cases need 2 of em'.
08-19-2012, 04:40 AM | #57 |
| Re: GCM Transfer Case Yes, we constantly make these. If they are out of stock at gcmracing.ca then check the dealers button. I think tcscrawlers has some. Our store stock should be back up shortly. Thanks Last edited by Generis; 08-19-2012 at 04:44 AM. |
03-09-2013, 08:00 PM | #58 |
hey man. got the t-case today, and for some reason no matter how i build it it completely binds, and i cant even turn the shaft while grabbing it with plyers. i tihnk the case is just pinching the pinion gears to the bearings against the case. i watched the instruction video many times, and have had one of the t-cases for a while and that one went together no problem. i have no gaps between the bearings and gears, and cant figure it out. i ahve been trying to make it work a hundred different ways all day... |
03-10-2013, 10:15 AM | #59 |
Sounds pretty odd to me! I'd love to see it myself. If you want to send it back, I'll send you the address, and build you one over here and send it to you. There's got to be something odd in that one!
03-11-2013, 01:42 AM | #60 |
Rock Crawler Join Date: Jun 2009 Location: UK
I had exactly the same issue. Mine was because the bearings would not slide onto the shafts. They would just slide on to the ends, but then got stuck when i tried to move them along the shaft, which caused the binding when i bolted the case together. I just polished the shafts up with some very fine wet/dry paper until the bearings could just about slide onto the shafts. Everything went together fine after i did that. |
