Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: GCM Transfer Case
Old 01-18-2014, 07:09 PM   #81
Originally Posted by Generis View Post
Here's a new assembly video and showcasing the new Transfer Case Shafts with screw pin holes!
GCM 1:1 Transfer Case Assembly and Update - YouTube
Wish you had those shafts earlier, will you sell just the shafts? I have two tcases I need through holes on
skerb is offline   Reply With Quote
Old 01-18-2014, 09:11 PM   #82
Default Re: GCM Transfer Case
Thanks for the note. It's a brand new change here, and it took us a couple of months to find a suitable shaft material to handle the abuse and fit our tolerances.
We can get the shafts out to you for sure, send a PM to us here and we will fix you up!
Generis is offline   Reply With Quote
Old 01-19-2014, 11:59 AM   #83
Moderator
badhoopty's Avatar
ditto here! sending pm!
badhoopty is offline   Reply With Quote
Old 01-19-2014, 05:56 PM   #84
WOW, well considering the response from the last couple hours, we now have a Replacement Updated Shaft listing at gcmracing.ca so anyone can order up a set!
Thanks for the comments and interest.
GCM
>>Updated T-Case Shaft Set Link<<
Old 01-19-2014, 06:06 PM   #85
So just to confirm, this is a different shaft material suitable for the loss of material in the area of the thru hole?
Thanks for listening guys
Meatwad is offline   Reply With Quote
Old 01-19-2014, 06:07 PM   #86
Thanks for the comments!
If you can break one with RC power, I'll send you a free replacement. Is that confidence enough?
Old 01-19-2014, 06:34 PM   #87
Hell yes and thank you
Old 01-19-2014, 07:44 PM   #88
Moderator
badhoopty's Avatar
on my crappy old smartphone i cant get more than one set in my cart!
will get on a computer before i bug you with another pm.
Old 01-23-2014, 02:03 PM   #89
I just have a question on the gears. Are they 32 pitch? I'm glad you guys did the through hole shaft design, That's what I've been waiting for.
rockhugger is offline   Reply With Quote
Old 01-23-2014, 02:47 PM   #90
Yes. And if your question is regarding durability, I'm running a locked spur with a Holmes 540 revolver S on 3s without a hiccup. Others run 4s through this tcase.
Old 01-23-2014, 05:55 PM   #91
I've managed to twist off a few steel driveshafts with this. And some of the original tcases are still in service in trucks we know!
Yeah, long lasting.
Old 01-30-2014, 08:10 AM   #92
Got my new shafts in for my GCM tcases. These things look great and make it much easier to work on.
Old 01-30-2014, 08:20 AM   #93
Good stuff! If you have any hard time getting your pins into the 2 ended shaft, make sure it's centered in the housing. There is a little adjustment available on the gear setscrew.
Nice TJ build!
Old 01-30-2014, 08:28 AM   #94
Nice TJ build!
Yep, I ran both jeeps in the snow yesterday with the new shafts. When assembling make sure you test fit a driveshaft on each end of the shaft before installing the case into the vehicle. They worked great! And made it one less thing to worry about with the through pin instead of the set screw.
Old 01-30-2014, 08:34 AM   #95
GCM
ur products are great but one thing iv always wanted is the RR gear to have outputs like that u should FAB one up
Ohioskills is offline   Reply With Quote
Old 01-30-2014, 10:44 AM   #96
Ohio, I have no idea what you just said!
Old 01-30-2014, 11:02 AM   #97
He means
Make strong outputs for an axial tranmission. by using the new stronger material.
kaneohecrawler is offline   Reply With Quote
Old 01-30-2014, 11:08 AM   #98
Ah, ok! Well, Rick at supershafty already killed that and there's other decent options available also, so not a GCM tendency.
Old 01-30-2014, 11:53 AM   #99
Originally Posted by kaneohecrawler View Post
He means
Wot r u tawkn bout. ur craZ.
Tommy R is offline   Reply With Quote
Old 01-30-2014, 12:04 PM   #100
lol sorry I was at work
you should copy the Robinson Racing Outdrive an put the hole on the shaft so i can put a full set screw pin threw because im always spinnging drive shafts off
You may edit your posts
