Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Standalone Axial based Gearbox
Old 11-13-2013, 04:21 AM   #1
Default Standalone Axial based Gearbox
N/a
Hulksta is offline   Reply With Quote
Old 11-13-2013, 05:54 AM   #2
Default Re: Standalone Axial based Gearbox
Very clean and at an amazing price!
Calderwood is offline   Reply With Quote
Old 11-13-2013, 06:38 AM   #3
Payment sent! Thanks again!
M_ENERGY is offline   Reply With Quote
Old 11-13-2013, 07:00 AM   #4
Passenger side ordered!
Is the skinny version you mentioned in your build thread available?
ROWDY RACING is offline   Reply With Quote
Old 11-13-2013, 07:15 AM   #5
Great work on the transmission Dan! That's how a parts explosion should be done
ittybitty is offline   Reply With Quote
Old 11-13-2013, 09:20 AM   #6
E.Y. Designs
Glad I got mine ordered up the other day Looking forward to getting it
EverettY is offline   Reply With Quote
Old 11-13-2013, 12:26 PM   #7
Money sent
McTwist is offline   Reply With Quote
Old 11-13-2013, 04:11 PM   #8
Very cool pay pal sent.
kam2040 is offline   Reply With Quote
Old 11-13-2013, 05:53 PM   #9
Amercian passenger or Australian passenger?????
Colgout is offline   Reply With Quote
Old 11-13-2013, 07:11 PM   #10
Mercian.
Old 11-13-2013, 07:40 PM   #11
What's the final gear ratio out of your gear box?
BigSki is offline   Reply With Quote
Old 11-14-2013, 02:27 AM   #12
Firstly guys, A BIG thanks for the support I think we smashed the limit of the first batch in under 24hours I will add up the numbers tonight and let yous know but my phone was buzzing away all day with alerts! got 42 PM's to get through as well to keep me extra busy lol
Ok I want to point out the left/right.. there is a little confusion so ive made this image to solve it
Yeah next to no profit on this, just wanted to give a little treat pre Xmas to crawler brothers
Yep if that's what you want LMK Did I post sizes on that one?
Thanks man... Nothing to hide is the way I like it, I also wanted images to display how they go together to help guys build them, Solidworks is a great platform to do the job
Never took the time to work it out, XR gears in a AX10 is not a new thing, a RCC member started it with what he called "front side jones" (search RCC) which provided another option... story for me is that I went to fit a FSJ to my sons rig earlier this year and found mounting them wasn't ideal, this kicked off months of work which ended up with this and the Joker chassis... Its been an enjoyable process and has me excited about sportsman again after 2 years void
Pinion size seems to be 16t - 20t so you'll find the gearing taller but it also gives users a greater range of pinions to choose from slow-fast crawler!
Old 11-14-2013, 03:10 AM   #13
Can I ask guys who ordered drop me a quick PM confirming left or right re; the above image.. want to make sure we are all on the same page
Also a few have asked for the "skinny" option, just confirming for yous the skinny GB is a go ahead
Old 11-14-2013, 03:45 AM   #14
These are the gears you'll need from the XR10 (in green) and the one highlighted in purple is the gear the Ti mainshaft goes through... Pic thanks to RC4WD
Old 11-14-2013, 06:43 AM   #15
Ok the limit of the first batch has been reached... I'll post updates on orders as they are completed
Materials for second batch won't be far off, once it arrives I will inform... Again it will be first in first served
Old 11-14-2013, 04:53 PM   #16
Pm'd regarding order amendment
Bc Paints is offline   Reply With Quote
Old 11-16-2013, 05:23 AM   #17
Regarding gearing reduction i have found on my HE Joker chassis (same gearbox layout) that i stepped up about 6 teeth on the pinion (at 20T now) to get a similar speed to my old AX10 box.
LAY80N is offline   Reply With Quote
Old 11-17-2013, 08:34 AM   #18
Main output shaft diameter? And is it a thru hole on each end of the output or a set screw divot?
Sorry if this was mentioned earlier
Old 11-18-2013, 02:52 AM   #19
Hi mate, 5mm with the set screw divot... Ive had a few guys asking for a hole through in 2.5mm, I don't like the idea of a hole through as it takes a lot of material out.. But if this is what guys are wanting?? I'll need to know ASAP
Old 11-18-2013, 04:02 AM   #20
Nice motto 'smashing the impossible'. I think it would be a good idea to have the 2.5mm hole as an option as a lot of us run maxx shafts. Don't forget about the losi version though.
PS if you need any testers....
pajey is offline   Reply With Quote
Standalone Axial based Gearbox - Similar Threads
Standalone axial based Gearbox Hulksta Axial AX-10 Scorpion 42 11-19-2013 07:11 AM
VP gearbox fit on Axial HD motor plate patoff Axial XR10 3 06-21-2013 01:16 AM
Axial gearbox gear measures tarmo120 Axial SCX-10 0 08-31-2011 11:43 AM
You may edit your posts
