07-13-2011, 07:32 PM | #61 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i had an issue when i mounted tires/wheels on stock axial straight rear axles shafts....i have RC4WD pro 10 1.9 stamped steel wheels with just axle pin slots....i'm still thinking of going with VP hexes for these wheels if i need to get clearance, has any body else had this issue with these wheels as well.... http://store.rc4wd.com/Pro10-19-Stee...ck_p_1414.html when i tightened them down with the axle nut they locked the axle from spinning....only thing i can see where it happened is the wheel got pulled against the alum axle bearing retainer cup....i pulled the tire off then removed the alum cup and put tire back on and free as willy the whale....can i file down the outside end of the alum bearing cap to gain the clearance i need....so i don't have the step showing where the cap should be in place, or can i get two caps with the ends CNC/turned down from you ........bob .... |
07-13-2011, 08:16 PM | #62 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
I have a set of those rims, and I have machined them down for customers also. They don't fit directly onto any Axial stuff. They have the pin drive slot way too far inset, so the hub just binds right to any housing. Very sad, they look great. The fix is to take 1/32 off the back of the hub, then they work (for any axial stuff). rc4wd uses the same hub on the stamped steel wheels, and has the same fitment problem. The problem is not the bearing holder, it's the rim hub. The axial stockers have the same dimensions as the Metalheads, so considering those rims will lock up on the stock axial housing, well.. they lock on the Metalheads. Try to trim off the hub first, that way you keep the integrity of the Metalhead parts. The hub will work the same way shaved down or not. |
07-14-2011, 12:26 PM | #63 |
thx for the fast reply ....yeah i was gonna look into trimming the wheel hub as well........bob .... |
07-18-2011, 11:07 AM | #64 |
Moderator Join Date: Jan 2004 Location: chicago
just pre-ordered a set. still on track for shipping late july? |
07-18-2011, 03:00 PM | #65 |
Going to be a close one, but if not end of the month, it will be mid week at the beginning of August.
07-18-2011, 04:12 PM | #66 |
awesome. |
07-25-2011, 06:12 PM | #67 |
I am in the middle of another MetalHead run, if you want them by August 6 shipping, then better get your orders in now. MetalHead Axle Housings by GCM Racing . |
07-31-2011, 04:30 PM | #68 | |
Newbie Join Date: Sep 2008 Location: Central Connecticut, United States
08-03-2011, 02:57 PM | #69 |
it will be real narrow, the short side is tiny on this thing.
08-09-2011, 09:23 AM | #70 | |
08-09-2011, 11:15 AM | #71 |
Done and shipped out, and as usual your shipping info was sent to your payment email address. We also made a couple of extras of each, so there's some stock now. |
08-09-2011, 04:46 PM | #72 |
has anybody received axles from this last batch yet? i havent and am getting concerned they have been vaporized somewhere in the mail.
08-27-2011, 06:43 PM | #73 | |
Don't forget, if you don't want to do any welding on the customizer, you can use a DMG Truss on a Standard set of MetalHeads, and it's all ready to mount. | |
11-04-2011, 04:19 PM | #74 |
Pebble Pounder Join Date: Nov 2010 Location: SL,UT
Here are a couple pics with the DMG Trusses... sorry it took so long but I just got them painted. (A year later lol) It is a beautiful combination of metal!! |
11-04-2011, 08:26 PM | #75 |
That lives up to it's license plate! Nice!
11-04-2011, 11:01 PM | #76 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
I recognize those plates |
11-07-2011, 02:36 PM | #77 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
Another set of MetalHead axles with the DMG truss. I used to have trouble with the axle c's coming loose. I think those days are over now. |
11-07-2011, 10:52 PM | #78 |
I wanna be Dave Join Date: Dec 2009 Location: Outside DC
very nice! The new DMG truss design looks sharp too! |
11-08-2011, 03:31 PM | #79 |
11-24-2011, 11:36 PM | #80 |
Quarry Creeper Join Date: Sep 2011 Location: NW
Will you be doing AR60 axles? If so I'd like to preorder a set.
