Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: GCM MetalHead Axle Pre-Order Now Open
Old 03-28-2011, 10:12 AM   #1
Default GCM MetalHead Axle Pre-Order Now Open
This is the release for the first run of MetalHead Axial Axle Housings designed by Jens. These are scheduled to ship out April 25th in time for MSD. Thanks. Tell your friends, and get orders in now. They are strong and they are expensive.
Please see the MetalHead review in RCCA October 2011 >>Here<<
>>> PRE-ORDER HERE <<<
This unit is a STEEL axle center section, a one piece unit that houses ALL the axial locker and ring gear combinations (best we can tell), and hold a set of STEEL axle tubes. You want strong, this is it. You want to make a custom 3 Link or 4 Link, you can weld it right on. You want clean, these are the most scale set of axles you can get for Axial parts.
__________________________________________________ ______________________________
Shown below is the 'Customizer Set' which has NO tabs for mounting, no holes for links or anything. You will need to braze or weld on your links/leaf/shock mounts. These have no finish at all, bare steel, bare aluminum.
Included in each order for a rear axle is:
2 aluminum rear bearing holders
2 steel axle tubes
1 steel center carrier
1 aluminum rear cover
1 aluminum 3rd front pinion member
all hex hardware included.
$150
Included in each order for a front axle is:
2 steel axle tubes (for Axial knuckle parts)
$140
>>> PRE-ORDER HERE <<<
__________________________________________________ _______________________________
Shown below is the 'Standard Set' which includes lower link tabs for mounting, and the screw boss holes up top on the axles to use any of your current tab-mounted stuff. The tubes have strong screw threads in them to hold your truss or leaf mounts. The tubes also have strong threads for a lower link mounting tab that screws on the tube. The Axial Y link on the top of the diff, or diff mounted servo, is not supported with this design. These have no finish at all, bare steel, bare aluminum.
2 steel axle tubes
2 aluminum top screw boss tabs
2 aluminum lower link mount tabs
$188
2 steel axle tubes
$177
>>> PRE-ORDER HERE <<<
The front axle is designed to take your CURRENT axial axle steering components and C hubs. What you have should be a direct fit. On the rear, your lockouts you have now are not needed, and the long tubes have a fully integrated aluminum outside bearing carrier made to fit.
Generis is offline   Reply With Quote
Old 03-28-2011, 10:41 AM   #2
so sexy, now if i could only get that 2 speed transfer case along with it
dezrik is offline   Reply With Quote
Old 03-28-2011, 10:56 AM   #3
www.team3sixrc.com
Thanks Generis for all the hard work. Ill be making my order Friday.
team3six is offline   Reply With Quote
Old 03-28-2011, 06:45 PM   #4
Thanks for producing these and dealing with all of our crap while trying to figure them out!
Sucks they won't be a normally stocked item.
Pointman is offline   Reply With Quote
Old 03-28-2011, 08:49 PM   #5
when you say 100, do you mean 100 sets with a front and rear or 100 single axles ordered, i'll order friday........bob
bob1961 is offline   Reply With Quote
Old 03-28-2011, 08:59 PM   #6
I have to make at least a hundred pigs, how they come can vary. If there's enough orders I'll try to keep some in stock, but its got to top a hundred to get started.
Old 03-29-2011, 05:43 AM   #7
ok thx generis....so you will be doing at least a second order of 100 for the people who might miss out that have to wait till this friday the order a set if they sell out fast .........bob
Old 03-29-2011, 05:41 PM   #8
i will be ordering a set next friday this friday rent is due thanks for the hard work
muddawg is offline   Reply With Quote
Old 03-30-2011, 10:34 AM   #9
Scale Detail Engineering
Do you have any real pictures of them?
These are 3d renders right? I'm just wondering how smooth the bevels are.
johnnyh66 is offline   Reply With Quote
Old 03-30-2011, 10:36 AM   #10
I'll get you some pics after the first run is off. They should be real close to the renderings with only some basic tool markings on them.
I also had a cool idea for a 3/4 link truss to bolt to the top of the 'standard' units. Going to hammer that one out after the first set gets done, and then I'll put up the offering on the site.
Old 03-30-2011, 02:34 PM   #11
that's the best looking axle I've ever seen. all i can say is WOW.
Goatsniper is offline   Reply With Quote
Old 03-30-2011, 08:21 PM   #12
so as long as i have my order in before the 11th of april i'm good right i want these axles really bad
Old 03-31-2011, 06:59 AM   #13
Anyway we could possibly get some rough dimensions? Just so we can play with designing our mounts while we wait.
LuckyDevil is offline   Reply With Quote
Old 03-31-2011, 07:23 AM   #14
www.team3sixrc.com
Rough? Same length as axial axles. No need for rear lockouts anymore.
Old 03-31-2011, 07:41 AM   #15
I was thinking more on height/width of pumpkin(center carrier width would work fine) and tube O.D. I understand length is the same. Sorry I wasn't clear.
I just want to start designing.
Old 03-31-2011, 09:01 AM   #16
tube od is .625, the total center section is 1.594 high and 1.927 wide
Old 03-31-2011, 09:44 AM   #17
Thank You, sir!
Old 03-31-2011, 08:46 PM   #18
can we get an update on how many axles have been pre ordered as of now....as soon as i get notice my money is in the bank i'm ordering a set....just curious how many have been ordered so far.......bob
Old 03-31-2011, 08:55 PM   #19
got a bunch of orders, but not near a hundred yet. There's still 11 days. Keep it coming
Old 04-05-2011, 08:44 AM   #20
Just curious hows the pre-orders coming? I'll put mine in soon, I got paid today.
You may edit your posts
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
