![]() | #1 |
Wanna get? Gotta want. ![]() Join Date: Apr 2010 Location: SLC, UT
I am happy to announce the No slop king pin bushings for Bergs, AX10, SCX10 or anything else using an Axial knuckle. Again, I am proud to say that this is 100% made in the USA from start to finish. These bushings are precisely made to remove all the slop that the stock bushings give. Important notes: The bushings are made to work with the stock stainless steel screws. If you use a different brand stainless screw, aluminum screw, steel screw etc,. you may find some will not even fit or be sloppy. Your knuckles must be in GREAT shape. Any burrs or gouges can cause the bushings to not fit correctly. I can only guarantee the tolerances of these bushings. If the tolerances are off on the knuckles or C's from other manufacturers these may not fit correctly. Axial version: Verified to fit: VP brand zero ackerman knuckles Axial brand high clearance knuckles These can be used whether you use Axial brand C's or stock Berg (both measure the same). These should work for many of you guys running AX10, SCX10, Bergs etc,. Contact me if you're unsure if these work for you. DLUX FAB | Products Berg version: Verified to fit: VP brand Berg knuckles Stock Berg knuckles (tight fit) These can also be used whether you're using Axial C's or stock Berg C's (both measure the same). $9 DLUX FAB | Products International I am offering these with CHEAP shipping. It will only be $3. This will NOT give a tracking number OR insurance. If they dont show up that is how it goes. Sorry. If you do not like those odds contact me and we can get a quote for tracking numbers and insurance. ![]() Last edited by Erik D_lux; 03-21-2012 at 07:54 PM. |
![]() | #2 |
Relaxed ! ![]() Join Date: Apr 2009 Location: On the road again !
This is bitchin, I was lookin at buyin some new ones today from the lhs but they're douchebags and u have to order everything or drive an hour to our sickass hobbytown in concord Well now I can order and at least they're made in the usa |
![]() | #3 |
Rock Crawler ![]() Join Date: Nov 2009 Location: Wildwood
Your best invention yet. I just ordered 2 sets.
![]() | #4 |
![]() | #5 |
2013 2.2P Nat. Champion ![]() Join Date: Sep 2009 Location: BorderLine Crawlers Season 3 is on!
Nice work EDL. I got tired of the slop a while ago and made my own. Big difference. I hate making them though. Do yours work with VP Axial zero ackerman knuckles. The knuckles in your photo have a detent at the kingpin that is not on the AZA knuckles. I guess I'm asking how tall are they in thou.
![]() | #6 | ||
| ![]() Quote:
Thanks! Thanks! Quote:
The picture shows a VP Berg knuckle. They are different as you noticed they have a relief in the top of the knuckle. The also measure differently in a couple other dimensions. These do work with the VP Axial zero ack (what I am running). You just need the Axial version above. I could give you all the dimensions if you need through PM. I would rather keep it off the public forum though. | ||
![]() | #7 |
Hey Erik, Thanks for the props. I'm glad you are making them. VP has enough cash already. I figured the AZA knuckles were different. I appreciate the offer on the sizes but with my non-stock screws as well, I'll make another set if I need them. I'll definitely hit you up for some if I switch knuckles. Looking forward to watching your build. Hope to catch you at a comp soon. J |
![]() | #8 |
![]() | #9 |
Damn! 32 minutes later and I have a shipping notice!
![]() | #10 |
| ![]() I really get off on shipping items as quickly as possible. It makes me happy because I know I LOVE getting my parts as quickly as possible. Thanks for the order! BTW, these are going faster than expected. I should have a bunch in stock for a bit but I can already tell I will need to order more soon. |
![]() | #11 | |
| ![]() Quote:
Thanks for creating an awesome product line and for the over the top customer service. | |
![]() | #12 |
Pebble Pounder Join Date: May 2009 Location: Scotland
Wow , another essential part for berg owners ![]() 2 sets ordered , cheers Erik ![]() |
![]() | #13 |
Spectacular service. I ordered on Wednesday, they arrived in Fl today. Thank you. ![]() ![]() |
![]() | #14 | ||
| ![]() Quote:
Anyway, let me know how they work guys! I think you will be happy with them. | ||
![]() | #15 |
What knuckle is pictured above? I am asking because my version 1's don't clear the top of the knuckle. I am running VP Axial High Steer knuckles. The ones you sent me are shorter and they cause the knuckle and screw to bind.
![]() | #16 |
| ![]() The above knuckle is a Berg knuckle. Is your knuckle a NON zero ackerman knuckle?
![]() | #17 | |
| ![]() Quote:
Edit: I see that you changed your product description to reflect new findings. It sucks that these wont work with MY vp Axial High Steers. Last edited by helhedded; 05-31-2011 at 12:10 PM. | |
![]() | #18 |
RcBros Hobbies ![]() Join Date: Nov 2005 Location: Oregon
What set would I need for our knuckles?
![]() | #19 |
| ![]() Thanks for asking. I was just checking them out. ![]() Edit: I take that back. Looks like yours are quite a bit narrower between the C's to fit with these. Also, I just found out that the Axial brand high steer version fits like a glove. Last edited by Erik D_lux; 05-30-2011 at 09:07 PM. |
![]() | #20 | |
| ![]() Quote:
Your knuckles are thicker than ANY other knuckle measured, by a lot! Your knuckles are measuring .008 thicker on just the ear. That is some wide tolerances if thats the way it came from the manufacturer. The other set that is having an issue measure correctly but it sounds like there is something blocking the bushing from going all the way in. I edited the first post to reflect that I cannot guarantee other mfg's tolerances and that the knuckles need to be in great shape. I can only guarantee my part tolerances. If anybody is having issues please let me know. Last edited by Erik D_lux; 05-31-2011 at 12:04 PM. | |
