03-07-2012, 02:40 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Virginia
| Axial XR10 Axle Mounted Weights Axial XR10 axle weights are made for comp crawlers looking for a little extra weight. Tuners like them because they are easy to take on and off especially if you have removed the stock sliding steering bar... although the weights DO work perfectly fine with a stock setup. Axle weights snap onto your axle tube and stay in place with a single 3mm stainless steel set screw. Weight: .8 oz. each. Black satin powdercoat. Please think before ordering . If you have mounted something in this area different from the stock setup then they WILL NOT WORK FOR YOU !!!! BMRC XR10 Front Axle Weights Last edited by Blue Monkey RC; 04-12-2012 at 11:10 AM. |
04-12-2012, 06:49 AM | #2 |
Quarry Creeper Join Date: Oct 2009 Location: Newton
What is the price for these?
04-12-2012, 11:10 AM | #3 |
| Re: Axial XR10 Axle Mounted Weights |
05-15-2012, 06:14 AM | #4 |
just made another batch of these. i'm glad this product is catching on because its a great way to add weight to your XR10 front axles.
05-17-2012, 04:22 PM | #5 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
These look really slick. How much are they shipped? Wes |
05-17-2012, 08:44 PM | #6 |
Axial XR10 Axle Mounted Weights - Similar Threads | ||||
Axial XR10 Stock Knuckle / Axle Weights | Blue Monkey RC | Axles, Trannys, T-case | 251 | 05-17-2014 06:49 AM |
Axial XR10 Knuckle weights | Erik D_lux | Axles, Trannys, T-case | 80 | 09-11-2013 09:39 AM |
What are youre XR10`s axle/corner weights? | Ola | Axial XR10 | 2 | 10-25-2011 12:08 AM |
