07-12-2006, 02:57 AM | #21 |
I wanna be Dave Join Date: Apr 2005 Location: Eastern WA
I caught it too! I was like hmm thats not right, was about to look it up! But im not that anal jk!
07-12-2006, 06:55 AM | #22 | |
so maybe you should see if we can find a contact for them since you work in a LHS Mike | |
07-12-2006, 02:28 PM | #23 |
Newbie Join Date: Nov 2004 Location: Flint
| Would be nice!!
Would be nice to get ahold of some. I know it has been done and actually someone on this site that does manufacturing and milling is gonna start making them. I cannot remember which guy. So obviously it can be done.
07-12-2006, 10:47 PM | #24 |
Pebble Pounder Join Date: Sep 2005 Location: Bellevue
a 9 tooth should be possible, the motor shaft just wouldnt be able to go thru the entire pinion...might not be as strong (due to the moment put on the shaft), but possible. no? about those 10 tooth pinions, i would kill for one of those, or 11, whichever. are 11's easier to come by, if so where!!!!!? |
07-12-2006, 10:55 PM | #25 |
Pebble Pounder Join Date: Dec 2005 Location: West ky, Benton
this what i found at tower www.towerhobbies.com: This is the Robinson Racing 32 Pitch 9 Tooth Pinion Gear. FEATURES: Standard alloy 32 pitch pinion gears are a great replacement for many Kyosho cars and any cars that use 32 pitch pinion gears INCLUDES: One Robinson Racing 32 Pitch 9 Tooth Pinion Gear with set screw SPECS: Inner Diameter: 1/8" (3mm) Outer Diameter: 0.33" (8.5mm) Last edited by Nylintjunkie; 07-12-2006 at 10:58 PM. |
07-12-2006, 10:55 PM | #26 |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Yes we see your posts, we just don't care.
07-12-2006, 11:00 PM | #27 |
what is ur problem i just posted a pic of the 9 tooth i found?
07-13-2006, 09:14 AM | #28 | |
Quarry Creeper Join Date: Apr 2006 Location: Cincy
Honestly, the problem is that we all know that they are available in 32 pitch, this thread is about a 48 pitch 9T pinion that would fit on a 1/8" motor shaft. GRRRRR!!!!! And if you look close enough....you posted another picture of that 90 pitch red x again. We've already seen a picture of that | |
07-13-2006, 09:35 AM | #29 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Who'd have thought that something that seems so simple to clarify would still be going? |
07-13-2006, 09:42 AM | #30 |
I was wondering the same thing. Why is this thread still poppin up in my cpanel?
07-13-2006, 10:20 AM | #31 | |
It also gives me an opportunity to test out the theory: Ignorance can be cured. Stupid is Forever....... | |
07-13-2006, 10:47 AM | #32 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
07-16-2006, 12:45 PM | #33 |
yeah i was talking about 48 pitch. so nobody knows where to get an 11 or 10 i take it.
07-16-2006, 01:50 PM | #34 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
Get a bigger spur...
07-16-2006, 04:22 PM | #35 |
impossible with my setup.
07-20-2006, 10:26 AM | #36 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
MIP also manufactured 10T 48P pinions. Here is a picture of the instruction sheet: *Photo Credit: RCC Member Razer* |
07-20-2006, 11:31 AM | #37 | |
I just emailed RRP this Quote:
Mike | |
07-20-2006, 11:40 AM | #38 | |
http://www.astroflight.com/e/env/00012AIyp7zJwkkmys5J1y2/store/store-Parts.html?link=/store/store-type-tem.html&item=products:af-750 http://www.fxaeromodels.com/product_info.php?cPath=49_107&products_id=2459&osCsid=71ea20a88103899a898986 http://www.hpiracing.com/optionparts/op-pin.htm The standard motor has a 1/8" or 3mm shaft so, in theory, these might work for you. Have fun, spend $4, and motor on!!!!! | |
07-20-2006, 11:54 AM | #39 | |
Mike | |
07-20-2006, 12:12 PM | #40 |
Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
The HPI pinions are 48 pitch, but are made for smaller than 540 sized motors. The bore is around 2mm, they won't fit on standard 540 motors.
