04-30-2012, 03:02 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Virginia
| Losi Crawler Knuckle and Rear Axle Weights BMRC Knuckle and Rear Axle Weight Systems for Losi Comp Crawler and Night Crawler The weight of the knuckle kit is 3.7 oz per side and expandable. Outer weights are symmetrical and can be mounted on the bottom for a lower center of gravity or full circle for max weight: The rear kit weighs in at 2.0 oz and uses the same add-on weights as the front knuckle weight system: BMRC weight systems install in minutes. All brass weights are powdercoated satin black for a stealthy look with the wheel installed. Ditch the wheel weights and try some knuckle weights. You won't believe the difference in battery life, throttle response and way less breakage by eliminating the additional rotating mass. Losi weight systems can be purchased here: Losi Weight Systems Last edited by Blue Monkey RC; 04-30-2012 at 03:34 PM. |
05-01-2012, 04:10 PM | #2 |
Pebble Pounder Join Date: Sep 2011 Location: Albuquerque
| Re: Losi Crawler Knuckle and Rear Axle Weights
Will they work with the 20* alum knuckles?
05-02-2012, 08:19 AM | #3 |
| Re: Losi Crawler Knuckle and Rear Axle Weights |
05-02-2012, 09:04 PM | #4 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
05-03-2012, 01:03 AM | #5 |
Rock Crawler Join Date: Jan 2008 Location: NORWAY
What is the front weigths outer diameter ?
05-03-2012, 04:58 AM | #6 |
| Re: Losi Crawler Knuckle and Rear Axle Weights 40.65 mm as you know some beadlock designs don't use an inner ring and you can get away with a much larger diameter. if these weights will not provide enough weight for you and you want to pack more in there, BMRC makes custom weights for folks all the time... |
05-03-2012, 07:07 AM | #7 | |
| Re: Losi Crawler Knuckle and Rear Axle Weights Quote:
Thanks,40.65 mm is perfect for my wheels | |
09-21-2012, 03:34 AM | #8 |
just made a new batch of the losi crawler knuckle weights. thx!!
02-15-2013, 01:24 PM | #9 |
Losi Crawler Knuckle and Rear Axle Weights - Similar Threads | ||||
Axial XR10 Stock Knuckle / Axle Weights | Blue Monkey RC | Axles, Trannys, T-case | 251 | 05-17-2014 06:49 AM |
Losi Night/Comp Crawler Knuckle weights | Erik D_lux | Axles, Trannys, T-case | 76 | 09-11-2013 09:24 AM |
