Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Knuckle Weights for Yota Axles, Trailfinder 2
Old 04-30-2012, 03:30 PM   #1
Default Knuckle Weights for Yota Axles, Trailfinder 2
BMRC
Brass Knuckle and Rear Axle Weight Systems for RC4WD Yota Axles
The weight of the front kit is almost 2 oz. per side and expandable with extra weight:
The rear kit weighs in at 1.88 oz and uses the same add-on weights as the front knuckle weight system:
BMRC weights for Yota/TF2 install in minutes. All brass weights are powdercoated satin black for a very stealthy look after the wheel is installed.
Ditch the wheel weights and try some knuckle weights. You won't believe the difference in battery life, throttle response and less breakage by eliminating the additional rotating mass.
Yota axle weight systems were designed for stock TF2 wheels and other restrictive 1.9 wheels.
Please purchase from our website:
TF2 Weight Systems and Upgrades
Blue Monkey RC is offline   Reply With Quote
Old 05-15-2012, 06:20 AM   #2
Default Re: Knuckle Weights for Yota Axles, Trailfinder 2
Just sold our first set of these.
Go Kris! We will be following your comps to see how badly you beat everyone else with wheel weight!
Old 08-08-2016, 11:41 PM   #3
R these still available ?
JustMe is offline   Reply With Quote
You may edit your posts
