11-28-2012, 07:24 PM | #21 |
Quarry Creeper Join Date: Feb 2009 Location: In The BackYard Crawlin
| Re: GCM A-13 All Aluminum Wraith MetalHead Axle Housings Whats the price for us dollar. Like a set with 4 link and servo mount. I came up with 1 US dollar = 0.9927 Canadian dollars. So thats 235.00 for a set. Please correct me if this isnt right. Thanks |
11-28-2012, 07:26 PM | #22 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
That's right. The exchange is basically 1:1 right now. I didn't bother listing pricing with USD, as there's so little difference. Thanks |
12-08-2012, 08:43 AM | #23 |
Hey, everyone! THANKS for the pre-orders, and production has already started on these. If anyone wants to get in on the Dec. 14th shipping, get them in asap! Thanks!
12-08-2012, 04:07 PM | #24 |
Rock Crawler Join Date: Jan 2010 Location: rockford
Impatiently waiting.
12-12-2012, 06:30 PM | #25 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
Mine were ready so Chris delivered them to me this morning. Can't wait to get them in |
12-12-2012, 08:06 PM | #26 |
Those turned out sweet! Can't wait to get my black set.
12-24-2012, 12:15 PM | #27 |
Here's an overview of the Wraith Axle options: http://www.youtube.com/watch?v=vEigfKEq58s The next production happens early in January, so get your preorders in soon at gcmracing.ca! Last edited by Generis; 12-25-2012 at 12:54 PM. |
12-24-2012, 06:38 PM | #28 |
Well worth the wait. Mine showed up the other day. They really sweet. Thanks guys.
12-25-2012, 12:54 PM | #29 |
Thanks! The assembly instruction vid finally loaded! haha GCM A-13 MetalHead Assembly Info - YouTube |
12-27-2012, 09:26 AM | #30 |
Pebble Pounder Join Date: Dec 2004 Location: Acton
How the steering running VP knuckles since they make it a high steer? I really like these they look beefy. |
12-27-2012, 09:30 AM | #31 |
Thanks, they are really beefy. I don't have the high steer here to try out, but the VP C-hubs are fine. I'm sure the high steer linkage could be done if you wanted to, especially with a Panhard setup. The axle mounted servo might require some sort of bent upper steering link to work on the high steer knuckles.
12-27-2012, 06:25 PM | #32 |
I have the VP Cs, knuckles, CMS, panhard and steering links. The only minor issue is with the panhard mount which doesn't quite have enough space. Due to the design constraints, GCM had to move the link mounts out a bit which didn't leave enough space for the panhard mount, so either it or the steering C must be ground down a bit. Chris (GCM) was nice enough to shave down the panhard mount for me and as you can see here it's a small amount (< 1/16"): The steering links fit fine; the tie rod will just touch the diff cover at full steer but doesn't interfere, at least with the caster set back one notch. And as a bonus the panhard has more clearance than with the stock axle case. |
12-27-2012, 06:28 PM | #33 |
Is this considered 'high steer' or is this the normal setup? Looks like all the rest. I guess VP puts the steering link up a bit higher, don't they.. Neat!
12-27-2012, 07:05 PM | #34 |
I never had a stock Wraith steering setup so I can't compare to it, but if the steering is higher than stock then it's 'high steer', though often the tie rod is placed above the steering arms to achieve this. And anything higher than in my pics will just have more clearance, at least with the CMS setup, a servo on axle setup will be different.
12-30-2012, 06:50 PM | #35 |
I can see with a CMS it's fine but if you mount the servo on the axle tube it might be tight. But I'll figure it out. I'm selling some crawler stuff I don't use to buy some these axles are sick!
12-31-2012, 11:31 AM | #36 |
ok.i just sent payment for a set. thanx
04-06-2013, 09:20 AM | #37 |
We continue to manufacture these A-13 Wraith axles in 4 options. Front with Servo Front with no servo, and PanHard spot Rear standard Rear with steering, and servo on axle Rear centered, use RC4wd shafts, or make your own Generally we have most of the components in stock, and assemble kits to order. The batch pre-orders are done. |
04-06-2013, 12:27 PM | #38 |
These housings are awesome. I'd highly recommend these. |
09-04-2013, 07:43 AM | #39 |
Another quick note to say we are doing another big load of these next week. If you want mid September shipping, get your orders in now! Thanks for the replies and pics, everyone! Keep it coming! |
09-04-2013, 08:57 AM | #40 |
RCC Addict Join Date: Feb 2011 Location: York
Chris, will you be doing any in the scx10 width? Rj |
GCM A-13 All Aluminum Wraith MetalHead Axle Housings - Similar Threads | ||||
GCM MetalHead Axle Pre-Order Now Open | Generis | Axles, Trannys, T-case | 99 | 04-19-2013 12:30 PM |
Aluminum axle housings? | Brainstain | HPI Wheely King | 7 | 09-04-2012 03:00 PM |
generis metalhead axle housings......... | bob1961 | General Scale Talk | 8 | 04-05-2012 07:55 PM |
GCM MetalHead Axle Thread-For Axial Scale Truck | Generis | Axles, Trannys, T-case | 43 | 03-21-2012 07:30 AM |
looking for a pic of dmg axial axle truss on a gcm metalhead axle | badhoopty | Axial SCX-10 | 2 | 09-26-2011 05:59 PM |
