RCCrawler Forums
RCCrawler Forums (http://www.rccrawler.com/forum/)
-   Axles, Trannys, T-case (http://www.rccrawler.com/forum/axles-trannys-t-case/)
-   -   Berg rear shafts--- lightest and strongest (http://www.rccrawler.com/forum/axles-trannys-t-case/458608-berg-rear-shafts-lightest-strongest.html)
Erik D_lux 08-21-2013 08:33 AM
I just realized that I never put these shafts in the vendors section....
Well, here they are. I am pretty stoked about these. Not too many times do you get to make a part and they turn out perfect. Usually you have to adjust here and there, take some compromise and deal with what you need to deal with. Not these.
Introducing the DLUX rear axle shafts! :ror:
http://i180.photobucket.com/albums/x...g/100_3628.jpg
• They are made from 7075 aluminum and are 8mm at the hex, 7mm all the way to the locker.
• By FAR the lightest rear shafts available. These are OVER 1oz lighter than a steel 6mm shaft (for the pair).
• 8mm at the hex and no external threads means that you will never, ever bend the shaft at the wheel again.
• The shafts use a Bully style hex. The hex and pin are superior in design. The hex holds the pin in a double sheer design. This adds a serious amount of strength just by putting it in double sheer but then to add to it, the pin is 2.5mm vs stock Berg at 2mm. Much bigger. Never worry about breaking a pin or bending it. Tighten these down as much as you like also making a tire coming loose a thing of the past.
• Adds approx 3/16 per side or 3/8 over all to the track width. This lets you run a narrower hub for even lighter wheel combo.
• Uses the Dlux Delrin hubs for an even lighter setup.
• Setting up the Dlux Berg rear axle to be the lightest MOA axle available!
Erik D_lux 08-21-2013 08:34 AM
Re: Berg rear shafts--- lightest and strongest
I was very cautious about producing these shafts since I was skeptical of the aluminum. I cant even guess how much time the prototype shafts have between myself and my testers. I drive on average maybe 5 hours a week. I know my other testers are doing as much or more than that. These have been in testing since late Febuary and have held up great!
I know what some may be still thinking,... "Really, an aluminum shaft? No way!" I get it, I do. So, I know that there needs to be some faith put into these.
I thought about it and wondered how I am going to get you guys to put some trust into these shafts? Then, I thought, why should I expect them to put some faith into them if I don’t do it first?
I am going to do a “No questions asked warranty” for 2 yrs. The only exception is if you modify them. An exception to modifying is if you modify say, the hex area and then the part at the locker breaks, I will still cover them. If you modify them at the locker end and the locker end breaks, than that’s that, sorry. I will be straight up with you guys and take care of you. Just use common sense.
For warranty, you would be responsible for shipping to me and I will send you a brand new shaft.
How could you offer such a warranty if you do not believe in the product!? I am not here to lose money on these so you know they have to be good!
A couple of pictures for you guys...
Here is everything you will get:
Axle shafts
Dlux hexes that include pins
Bearings
7075 RC bros locker fit for the shafts
http://i180.photobucket.com/albums/x...g/100_3629.jpg
Over an ounce lighter than 6mm shafts!
6mm shafts with bearings 49g
http://i180.photobucket.com/albums/x...g/100_3159.jpg
Dlux shafts with bearings 18g!
http://i180.photobucket.com/albums/x...g/100_3617.jpg
A picture comparasion. Top to bottom.
6mm shaft, Dlux shaft, stock dog bone
http://i180.photobucket.com/albums/x...g/100_3156.jpg
Harvo 08-21-2013 01:56 PM
Running them for months now. Zero issues and a great product. "thumbsup"
Szczerba 08-21-2013 04:06 PM
I've been running these AL rear berg shafts since 9/21/2012 with no issues!
http://www.rccrawler.com/forum/enrou...ml#post3928652
TSK 08-21-2013 04:14 PM
Lightest, strongest, best hex/hub setup & a 2 yeaer warranty to boot8)
Hands down one of the best products available on the market today.
Erik D_lux 04-02-2015 08:48 AM
These are on sale now for just $70!
You get shafts, bearings and a locker for that price!
captainmorgan 04-06-2015 09:07 AM
Pm Sent. I'm trying to figure out everything that I will need for these and your tubes.
Beest 05-16-2016 03:25 PM
Pm sent.
Sent from my SM-G920P using Tapatalk
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
