08-25-2016, 07:48 PM | #241 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
| Re: **AX10/SCX10 Housing Splined Burly Tubes** |
08-27-2016, 11:00 AM | #242 |
Stock Width Brass and 7075 Burly tubes are on sale for a limited time. Only $35.00! Come get yours today Stock AX/SCX Width Burly Splined Tubes | |
09-23-2016, 07:40 AM | #243 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
I'm also interested in your wide width brass burly beef splined tubes. Any updates on when you will have these in stock?
10-19-2016, 09:54 PM | #244 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Had to order a set of brass narrow tubes as you have them on sale and I need to upgrade my rid |
10-20-2016, 03:13 AM | #245 |
Pebble Pounder Join Date: Apr 2016 Location: Long Island ny :(
Do you want "more of or all the weight on the front axle"? In this case meaning do people get your tube's for only the front or for the back too? I'm assuming for the front and the back to help plant the truck??? Also why the option of brass aluminum and steel? I know brass is heavy and aluminum light. Do people run different types in front and back? Thanks for any info, couldn't find a more in depth explanation. Sent from S5 using Tapatalk |
01-15-2017, 09:16 PM | #246 | |
| Re: **AX10/SCX10 Housing Splined Burly Tubes** Quote:
Most just use the tubes in the front as the biggest advantage of these tubes isn't weight, but the ability to upgrade to the splined chubs and knuckles, which give you a tremendous steering advantage. Most scale rigs use brass where most sportsmans drivers do aluminum. Sent from my iPhone using Tapatalk | |
07-02-2017, 09:35 AM | #247 |
First post has been updated. Burly Tube 2.0's are now available!
