![]() | #81 |
RcBros Hobbies ![]() Join Date: Nov 2005 Location: Oregon
![]() | #82 |
7075 Burly Tubes are now cheaper and offered in a cut version!
![]() | #83 |
I wanna be Dave ![]() Join Date: Jul 2009 Location: Rancho Relaxo. California. USA. Earth.
Order placed.
![]() | #84 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
![]() | #85 |
Pm me ur order info and which you would like to change to if at all. Sent from my iPhone using Tapatalk |
![]() | #86 |
![]() | #87 | |
| ![]() Quote:
![]() | #88 |
Once this process is done you drill and tap the tube itself on the ends and near the pumpkin Sent from my iPhone using Tapatalk |
![]() | #89 |
| ![]() That's easy on the front side, what about the side with link/shock mount, screw off center, grind the rib between lower link mounts or? Got a pic?
![]() | #90 |
I do a screw off center, grinding the rib and drilling center is another option. ![]() |
![]() | #91 |
Pebble Pounder Join Date: Aug 2011 Location: RF Moscow
Hi! Shipment to Russia received'll soon be installing! The question of why there are holes in bronze, and aluminum is not present?
![]() | #92 |
![]() | #93 |
I got my stock brass tubes and uni's yesterday, just waiting for the rest to get started.
![]() | #94 |
RCC Addict ![]() Join Date: Apr 2012 Location: Williamsport, PA
Received my 7075 tubes today to replace the delrin ones currently installed on the Suckerpunch. If you want tubes, these are the ones you want. Did a quick fit test and everything is perfect. Nice snug fit even without any screws. Thanks Will for going above and beyond with these. ![]() |
![]() | #95 |
![]() | #96 |
Quarry Creeper Join Date: Mar 2006 Location: Pewee Valley, Kentucky
How wide are these compared to wraith axles?
![]() | #97 |
![]() | #98 |
![]() | #99 |
![]() | #100 |
So are they measuring the same points as RCBros is?
