01-03-2014, 09:16 PM | #61 |
RCC Addict Join Date: Dec 2009 Location: Newcastle, Australia
| Re: Standalone Axial based Gearbox Done good for the first review just working off the pics Ive filmed a vid myself just haven't had time to edit/post yet... three things ive noticed in yours... 1.the CF ring is a bearing spacer, the flange on the front 10mm bearing goes outside the tranny and the spacer sits behind to keep the bearing from going into the gears (it give good clearance for the gears) 2.your right the extra standoff is there incase guys strip a thread or drill the hole in the wrong spot. 3.the standoff at the top that has the motor screw is best drilled out to 3mm so you can screw down tight on the motor. Thanks for taking the time man Im sure there are guys keen to hear how you go with it in the MRC too. |
01-03-2014, 10:54 PM | #62 | |
Rock Crawler Join Date: May 2010 Location: Calgary, Alberta, Canada
| Re: Standalone Axial based Gearbox Quote:
01-04-2014, 09:23 AM | #63 |
Ok guys ive hit my limit again, can't believe how quick these are going! Good news is bearings and screws are what I'm waiting on and they are already on order... 1-2weeks and we'll be in business again. I'll honor the $55 pricing until the end of January also Ive had people ask about ordering just the CF plates so they can swap to another style.. answer is yes $30 posted in a STD envelope.. Cheers Dan |
01-04-2014, 01:15 PM | #64 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
What's the benefits of using right or left versions?
01-04-2014, 07:37 PM | #65 |
| Re: Standalone Axial based Gearbox Its really just for setup allowing the builder to have the setup he is looking for... For eg if the builder wants the motor on the right and reverse the GB having it at the back bring the motor forward then he would need a left side tranny... And the great thing about the way I designed the long output shaft is you can have a reversed tranny and not need a long tailshaft up front |
01-04-2014, 10:23 PM | #66 |
| Re: Standalone Axial based Gearbox Can "Stanley" contact me via PM please.. Not sure on your user name on here? Wife will be posting last of the orders tomorrow guys |
01-05-2014, 09:23 AM | #67 | |
Rock Stacker Join Date: Dec 2013 Location: Fountain Inn
If the flange is on the inside the gear can stop it from walking. | |
01-05-2014, 09:48 AM | #68 |
| Its a snug fit and the outside bearing is on the short side and the drive shaft would keep it in.. atleast on mine and how its set up.
01-05-2014, 09:52 AM | #69 |
| Re: Standalone Axial based Gearbox yeah what winner123 sai, once you put on the driveshaft if it does try to walk, the driveshaft will hold it in... also the bearings are such a tight fit on the shaft i had to use a vise to get them on, i don't see it walking.
01-05-2014, 10:14 AM | #70 |
| Re: Standalone Axial based Gearbox |
01-06-2014, 01:33 AM | #71 |
Yep there is close tolerances in it all, I have a pet hate for sloppy parts, how ever I cant be 100% sure what driveshaft people will use and if ALL of them will work, I did design it and used 3 makes of tailshaft for testing.. Junfuc, MIP & Axial WB8.. I got it as close as I could to work with these (even test fitted a losi LCC one which was good too)..... OK so the point im getting to is with the front bearing (flange out) it is sandwiched nicely between the pinned gear and the d/shaft BUT with different d/shafts it MAY require a little tweek which i'll detail now for those that might be new to building rc's. If the front driveshaft is too snug on the bearing pull off the CF bearing spacer and sand it down to fit the d/shaft on, little bit at a time, don't get too carried away (this was the reason behind the CF bearing spacer, so the builder with a bit on sandpaper can build with no issues) Now if you find after you fit the driveshaft that there is a little slop between the d/shaft & bearing then use some wheel bearing shims (5mm ID) to shim it to a nice fit. There was a lot of work gone into thinking the GB design out, it looks basic at first but once you start to see the detail you can start to see how much time it took me to get it working right to make it suitable for a beginner (with a bit of know how) to a pro builder |
01-06-2014, 06:10 PM | #72 |
Quarry Creeper Join Date: May 2012 Location: enfield CT
| Re: Standalone Axial based Gearbox here's my two pennies right side torque steer or blipping throttle lifts truck up and gives more steering but can destabilize the rig if not careful of camber or climbing. left side torque sends rig downward creating more grip or traction on throttle no gain in steering at all. down fall if stuck it will bury it self into the rocks I like both ways 6 of one 1/2 of another |
01-07-2014, 09:14 AM | #73 |
Thanks for the tips Hulksta, got my tranny all assembled properly now, just have to figure out driveshaft for the fornt of the mini though, not easy sourcing (or making) a durable driveshaft that's like 45-60mm... i just wish MIP would quit being stupid and just spline their stuff all the way through so i can cut it to whatever length i want.
01-07-2014, 02:55 PM | #74 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
This is sweet but any pic of this mounted up in a Crawler?
01-07-2014, 03:00 PM | #75 |
| Re: Standalone Axial based Gearbox got mine mounted in my mrc, hist need to fit some driveshafts which i intend to do tonight/tomorrow, then i have to wait for my motor... mail is slow... T3rry's "Losi? What Losi?" Build |
01-08-2014, 08:33 PM | #76 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
this is pretty awesome. i think this would be pretty killer in a scaler too. i could do lots better on the scale interior with something like this. |
01-09-2014, 02:02 AM | #77 | |
Cheers Dan | |
01-09-2014, 07:19 AM | #78 |
cool dude. my main concern is how to box it all in to keep the grit out of the gears. us scalers really like to get things dirty. |
01-09-2014, 08:19 AM | #79 |
| Re: Standalone Axial based Gearbox i was thinking you could just put a screen material around it, should be easy to wrap around and secure it between the standoffs and the CF plate, that would keep out the junk, while letting through air and water, no biggy as long as you wash with clean water and let it dry well after... i dont think there would be any good way to seal it up completely.
01-09-2014, 08:09 PM | #80 |
RCC Addict Join Date: Nov 2006 Location: burlington
| Re: Standalone Axial based Gearbox This is what mine will be going in once it shows. I have had a few scalers with trans wedged up front and they seemed to stay cleaner than when in the stock location.
Standalone Axial based Gearbox - Similar Threads | ||||
Standalone axial based Gearbox | Hulksta | Axial AX-10 Scorpion | 42 | 11-19-2013 07:11 AM |
VP gearbox fit on Axial HD motor plate | patoff | Axial XR10 | 3 | 06-21-2013 01:16 AM |
Axial gearbox gear measures | tarmo120 | Axial SCX-10 | 0 | 08-31-2011 11:43 AM |
