BmachineRC Splined "Repair" tubes and "True" SCX 10 Width Axle <hr style="BACKGROUND-COLOR: #191b21; COLOR: #191b21" size="1"> http://www.rccrawler.com/forum/membe...3398-54123.jpg BmachineRC Will Be Closed For A Few Months!!! Ive been at this for 2 or 3 years now and have had a blast making parts for the RcCrawler community. Thank you !!! But unfortunatlly in that time I have gotten behind in other aspects of my life that I need to catch up on. If I have a chance to make any parts during my break, I will post them up. Thanks again to everyone who has used any of my products!!! SPLINED 7075 AX10 HOUSING TUBES Have an old housing with the ends snapped off...These are the tubes for YOU! Designed to use VP XR10 C-hubs THESE TUBES WILL BE OFFERED 2 WAYS: #1...REPAIR TUBES...$55.00 shipped Drilled and Tapped for VP C-Hub ( you will have to trim housing and drill and tap holes to mount in housing) #2...Tubes PRE - INSTALLED IN NEW HOUSING...$75.00 shipped (while housing supplies last) UPDATE: These tubes will work on the rear using XR10 VP lockouts and XR10 short side axle shafts with no mods...you only get .100 engagement into the locker. Please include which option you want in the PayPal notesLong side shafts milled down is a better option. My Paypal is : BmachineRC@gmail.com Please include which option you want in the PayPal notes Please include RCCrawler screen name in the PayPal notes __________________________ "STOCK SCX10 WIDTH AXLE TUBES USING VP WRAITH KNUCKLES" __________________________ ** Want more steering on your SCX10 axle? ** ** Been holding back on doing the XR / Wraith mod because you don't want your front axle wider than your rear? ** ** This may be what your looking for. ** http://www.rccrawler.com/forum/membe...3398-54794.jpg 7075 Spline tube with machined VP Chubs http://www.rccrawler.com/forum/membe...3398-50935.jpghttp://www.rccrawler.com/forum/membe...3398-54797.jpg http://www.rccrawler.com/forum/membe...3398-54798.jpghttp://www.rccrawler.com/forum/membe...3398-54799.jpg XR Universals With Re-Machined Tangs http://www.rccrawler.com/forum/membe...3398-54796.jpgThe Options : SCX 10 Tubes Only.... $48.00 Tubes with new VP C-Hubs.... $100.00 (Your choice of VP color) Tubes with New VP C-Hubs installed in New AX 10 housing.... $128.00 XR 10 axles with Machined Tangs.... $48.00 Wraith Knuckles.... $40.00 ( shipping times will vary based on non BmachineRC parts availability) (pricing may vary based on a lot of things) Thanks for looking My Paypal is : BmachineRC@gmail.com <!-- google_ad_section_end --> Please include RCCrawler screen name in the PayPal notes |
Re: BmachineRC Splined "Repair" tubes Great work on these Bruce! Having the option to pick up the housing already modified should be a great service to take some of the anxiety out of getting things set up correctly and not botching the threads the first time around. 8) |
Re: BmachineRC Splined "Repair" tubes Quote:
I know there are a couple other splined tube tubes out there, but it's always nice to have options"thumbsup" |
Re: BmachineRC Splined "Repair" tubes Those r nice looking Bruce keep me in mind when I go to build a sporty lol |
Re: BmachineRC Splined "Repair" tubes Gotta finish the pro first just pick up a awesome chassis from u sat need a lil more time lol |
Re: BmachineRC Splined "Repair" tubes I spoke with M_ENERGY about these on Sunday! I am impressed! |
Re: BmachineRC Splined "Repair" tubes Thank you sir. The ones Derrick and BIGJON have put a hole new twist on things"thumbsup" |
Re: BmachineRC Splined "Repair" tubes "True" SCX 10 Width Axle added to post "thumbsup" |
Re: BmachineRC Splined "Repair" tubes Do you have any of the SCX10 width splined tubes instock ??? |
Re: BmachineRC Splined "Repair" tubes Brian, my splined tube & axle housing just arrived today !!! Looks great, can't wait to finish assembling them. Thanks !!! |
Re: BmachineRC Splined "Repair" tubes 6 Attachment(s) I have to say that Bruce has an incredible product here. The one reason that I've waited on doing this mod is because I wanted the front axle to match the width of the rear axle. This set-up is spot on and is beefy as heck. For the axles, I went with new Vanquish VVD's. Vanquish did a set for me that has the SCX-10 axle shafts with Wraith stubs. With the new shafts in hand, I had to extend the axle flats 6mm and trim 5mm (could have trimmed only 4mm) off the ends. At full turn, I have 3-4mm clearance between the wheels and shocks (stock) so no rubbing there. Thanks Bruce for you help and advice. So on to the pictures. |
Re: BmachineRC Splined "Repair" tubes and "True" SCX 10 Width Axle Any chance on there ever being a metal version available at all? I like the idea of a metal version of the Repair Tubes to add a lil bit more weight to the axles than the aluminum version and the whole metal threads being way stronger than aluminum would be sick too! |
Re: BmachineRC Splined "Repair" tubes and "True" SCX 10 Width Axle Quote:
Re: BmachineRC Splined "Repair" tubes and "True" SCX 10 Width Axle New axle showed up yesterday! BND of BmachineRC did an Incredible job executing this axle setup! When I did the rear steer on my scx, I realized that the narrow XR mod still left a gain in track width. So when I saw the True width "repair" tubes from Bruce, I knew it had to be my new front axle! I sent a Dlux modded scx housing and a VP wraith C's to Bruce and let him do his work. http://tapatalk.imageshack.com/v2/15...9c32d1c590.jpg I used as many vendor parts as I could.. Dlux modded scx housing, BmachineRC "repair" tubes, and a HH torquemaster spool. http://tapatalk.imageshack.com/v2/15...c1341c6c17.jpg It all fits beautifully with the "repair" tubes! http://tapatalk.imageshack.com/v2/15...5740e4b06b.jpg |
Re: BmachineRC Splined "Repair" tubes and "True" SCX 10 Width Axle Bruce, do you do normal width xr shafts (the regular xr mod on the scx10 housing which is a hair wider than scx10 but narrower than XR) looking to run a press fit style locker and the tangs are very difficult to get nice and square while keeping the press fit size. Thanks, Ben |
I've been running this front axle setup and have absolutely loved it! Well worth the performance gain on this mod! |
