12-30-2013, 10:37 AM | #21 | ||
| Re: Wraith pinion bearing mod Quote:
I am finally home so I will get kickin and get your order out ASAP. I would guess so? I have a bunch of housings that I am going to look at such as the VP stuff so I will throw a SCX stock housing in and see how that works out too. | ||
01-02-2014, 09:47 AM | #22 |
The great news is that these are in stock again. The bad news is that the VP nor the SCX10 axles can accommodate this mod. |
01-06-2014, 06:06 PM | #23 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
Damn, so close.
01-06-2014, 06:13 PM | #24 |
Got mine today.. Awesome! Thanks Erik! |
01-10-2014, 06:01 AM | #25 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Erik is there enough meat on the VPs to do anything? Like a 12-14mm outer? Vp in my opinion failed on their housings. They copied a molded plastic part and machined it in aluminum. They really should have modified it to handle bigger bearings from day one. |
01-10-2014, 08:19 AM | #26 |
I am guessing that you could do a smaller bearing on both the SCX and VP housings. The VP was so very close that I think the exact point where the bearing went was 16mm. It was almost held together by the paint but I knocked it off with my finger. The question is: If you do a 14mm bearing, is 1mm wall thickness enough? I would say there is a good chance, but it would need to be tested. 12mm would give a 2mm wall thickness which should be good but is 12mm vs a 10mm worth the time? Maybe, but it would need to be tested. |
01-15-2014, 12:22 PM | #27 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
when do you expect stock?
01-15-2014, 02:13 PM | #28 |
In about a week I should have a TON more.
01-15-2014, 02:40 PM | #29 | |
01-15-2014, 04:24 PM | #30 |
RCC Addict Join Date: Dec 2012 Location: Crookston
Think I might need one of these for my Wrexo.
01-16-2014, 10:26 AM | #31 | |
Pebble Pounder Join Date: Dec 2013 Location: Keller
Are you replacing both inner and outer? | |
01-16-2014, 11:05 AM | #32 |
Just the inner
01-16-2014, 11:27 AM | #33 |
| Re: Wraith pinion bearing mod |
01-16-2014, 12:26 PM | #34 |
01-16-2014, 12:39 PM | #35 | |
I'm trying to determine which bearings to order for the Vanquish housing: 5x13x4 or 5x14x5 Looking at the Vanquish pics... 11mm stock, it appear to have 1mm crown to hold the stock outer bearing that extends inside towards the inner bearing, so should at least hold the 13mm, perhaps the 14mm, but that pushes the pinion towards the ring 1mm. IF ONLY I were home with the parts rather than here in the sandbox... trying to gather everything and have it ready for my upcoming 2 weeks R&R. | |
01-16-2014, 12:44 PM | #36 |
01-16-2014, 12:44 PM | #37 |
Yeah, I do a 5mm thick bearing. Either bearing youre looking at should do the trick, just set the depth as you go along. |
01-22-2014, 06:44 PM | #38 |
I am putting these back in stock and should be ready to ship tomorrow. |
01-23-2014, 05:53 PM | #39 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
Mine showed up yesterday.... man those bearings are beefy!! Going to be a huge improvement in durability. Im so impressed that Im ditching my brand new Vanquish housings to run these housings. Now im going to have to order a set for my boys Wraith too. Thank you Erik!! |
01-23-2014, 05:59 PM | #40 |
Btw Erik... What do you recommend for the outer with your housings? Bearings or Traxxas bronze bushings? Thanks, |
Wraith/AX10/SCX10 pinion bearing mod - Similar Threads | ||||
AS-3 Bearing mod | Kaptain | Axial SCX-10 | 27 | 04-08-2014 11:43 PM |
Bearing mod | chessmaster | Axial XR10 | 10 | 03-17-2011 02:45 PM |
9mm bearing mod | losichris | Axial XR10 | 21 | 10-07-2010 07:18 PM |
Pinion Bearing Walk? | sickfab | HPI Wheely King | 12 | 08-29-2007 01:28 PM |
