Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Wraith/AX10/SCX10 pinion bearing mod
Old 01-23-2014, 06:41 PM   #41
Wanna get? Gotta want.
Erik D_lux's Avatar
Default Re: Wraith pinion bearing mod
Awesome!
I would just use a standard bearing. The inner should carry most of the load and that outer bearing should last much longer because of it.
Erik D_lux is offline   Reply With Quote
Old 01-23-2014, 06:54 PM   #42
Perfect! That is what I wanted to hear.
Thanks again
Trugg is offline   Reply With Quote
Old 02-06-2014, 01:09 PM   #43
MEOW
Natedog's Avatar
Originally Posted by Erik D_lux View Post
These are now available on my site.
$20 per housing
Bearings are supplied with the mod.
  • Gears are setup so they do not spin freely and feel gritty. Testing has shown this is the best setup for durability.
  • Different axle housing and different gear sets can have different results, I can only set them up with the parts I have and count on the tolerances being somewhat close.
Very worthy looking mod, on my list!
Old 02-25-2014, 05:37 PM   #44
Nice work on these, what a bummer about the VP not having enough material...they shoulda done it in the first place...
Good work picking up all the slack in design errors and helping to fix them!
Just ordered the truss, gonna get these soon...
TheAxialNut is offline   Reply With Quote
Old 02-27-2014, 08:04 PM   #45
I have a set of GCM MetalHead axles I can send you if you want to try them.
wmajors is offline   Reply With Quote
Old 02-28-2014, 07:19 AM   #46
Erik D_lux's Avatar
Thanks!
I will let you know if I need a set.
Old 02-28-2014, 09:09 AM   #47
so all this does is put a bigger bearing in replace?
Ohioskills is offline   Reply With Quote
Old 02-28-2014, 10:15 AM   #48
What a cool mod ! Great idea !
Crawler Ted is offline   Reply With Quote
Old 02-28-2014, 11:02 AM   #49
Kinda....... But that one bearing does a Whole Lot! It not only puts a bigger, better, badder bearing in there, but it gives a Way better gear mesh as well.. like zero slop!
Well worth every couple extra pennies spent on the Dlux housings.
Just think, get 2 housings from Dlux and even if it Only saves 1 set of gears, the little bit extra spent on the housings is still less then the cost of that 1 set of gears..
winnerone23 is online now   Reply With Quote
Old 02-28-2014, 11:48 AM   #50
Erik D_lux's Avatar
Well said Winner. Thanks
Old 03-03-2014, 11:29 PM   #51
Curious as to the pricing of two housing w/ your CF trusses? One front, one rear.
Thanks.
Supper is offline   Reply With Quote
Old 03-04-2014, 07:31 AM   #52
Erik D_lux's Avatar
Please check my website.
Old 03-04-2014, 08:34 AM   #53
ive looked at these pics a few times and im not understanding what this is all about???
i get that you are stating the pinion is pushed up into the crown but... all i see is a bearing here?
SwampDawg is offline   Reply With Quote
Old 03-04-2014, 08:58 AM   #54
Bigger bearing=less failure
Meatwad is offline   Reply With Quote
Old 03-04-2014, 08:59 AM   #55
Re-read or read, post #49
Old 03-04-2014, 10:33 PM   #56
Was about to order. You are showing outta stock. Let us know. Thank you sir.
67mustang is offline   Reply With Quote
Old 03-05-2014, 07:19 AM   #57
Erik D_lux's Avatar
Planning on having more tomorrow or Friday.
Old 03-05-2014, 08:45 PM   #58
Helps if I actually read peoples signatures?
PM Inbound.
Old 03-07-2014, 10:46 AM   #59
Erik D_lux's Avatar
Back in stock and shipping Monday.
I have a handful but hoping to have even more soon.
Thanks for all the support guys!
Old 04-04-2014, 07:14 PM   #60
When I get some $$$ freed up I will be grabbing some.
jopes is offline   Reply With Quote
Wraith/AX10/SCX10 pinion bearing mod - Similar Threads
AS-3 Bearing mod Kaptain Axial SCX-10 27 04-08-2014 11:43 PM
Bearing mod chessmaster Axial XR10 10 03-17-2011 02:45 PM
9mm bearing mod losichris Axial XR10 21 10-07-2010 07:18 PM
Pinion Bearing Walk? sickfab HPI Wheely King 12 08-29-2007 01:28 PM
You may edit your posts
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
