Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Wraith/AX10/SCX10 pinion bearing mod
Old 04-21-2014, 02:24 PM   #61
Wanna get? Gotta want.
Erik D_lux's Avatar
Default Re: Wraith pinion bearing mod
These are now back in stock!
There has been a change...... I went from a 5x16 bearing to a 5x13 bearing. This leaves all the crucial materiel (no longer as deep) and then some but still gives a much better bearing than stock. In our testing we still did not wear out a bearing and had no housing issues.
In the picture there is a 5x13 bearing installed and to the lower left there is a 5x13 next to a stock 5x10 so you can see just how much bigger it still is.
Erik D_lux is offline   Reply With Quote
Old 04-22-2014, 03:03 AM   #62
Begs the question... are you able to install in a VP housing?
MAVERICKJK is offline   Reply With Quote
Old 04-22-2014, 07:51 AM   #63
Erik D_lux's Avatar
I dont see why it would be a problem for the VP housing. I am not sure I want to take the chance on a part that I make a couple of dollars on.
I can now see the SCX housing working also, if there were enough interest I would give these a shot again.
Old 04-22-2014, 08:04 AM   #64
I'd be in for scx housings.. After the abuse I put the wraith axles thru, in game!
Specially now the scx is running a HH trailmaster BL and testing it on 4s!
winnerone23 is offline   Reply With Quote
Old 04-22-2014, 08:22 AM   #65
Im game for a SCX10
Shinjari is offline   Reply With Quote
Old 04-22-2014, 08:59 AM   #66
Erik D_lux's Avatar
I have some SCX housings on order
Old 04-23-2014, 01:01 AM   #67
Natedog's Avatar
Very nice!
Old 04-23-2014, 02:27 AM   #68
will these handle high horsepower brushless systems??????
mikespeed6 is offline   Reply With Quote
Old 04-23-2014, 06:21 AM   #69
How high horsepower?
Pro4 4000kv on 4s with Zero remorse on the throttle!?
Pics all since I went with the Dlux mod housing and could actually keep gears in one piece...
All pics are of different breaks over the last month or so and of diff breaks.
I have so far lost/broke both stub shafts on the uni's and vvd's, bearings blew apart at the Knuckle's and outside edge of the axles and broke a rear axle shaft.. And Not once have I had a gear skip, pop, or the mesh loosen up!
Old 04-23-2014, 09:46 AM   #70
Natedog's Avatar
That is what they were designed for....U4 racing...
Sweet thanks for sharing the pics!
Old 04-24-2014, 04:09 PM   #71
Attachment 280499
Attachment 280500
Attachment 280501
Attachment 280502
Attachment 280503
Attachment 280504
What brand of ring and pinion are you using? Brand of bearings? Any other changes like still running a bushing anywheres? I dont count front axle failures as weak spots especially when it fails at the cross pin because all it takes is over tightening the axle nut one time to compromise the axle. Anywho im not running as much power as you are but are continuing to have problems and its not from binding up.
Old 04-24-2014, 09:24 PM   #72
I'm running axial hd gears with stock ratio now. I ruined a handful of gears before switching to the modded axles. I tried bearings and bushings before. And that was just with a 13.5t redline on 3s.
I'm running fasteddie bearings thru out.
I don't consider anything a weak spot, not when I'm behind the wheel!
I just like destroying shiz and this is my rig for just that.
Got my VP vvd V2 (5mm) stub shafts today. Can't wait to get my new rotor so I can put them thru there paces!
Next will prolly be some lockedup rc OT shafts for the rear, once they come out. I should be pretty solid then.
Old 04-25-2014, 12:18 AM   #73
Upgraded rotor for the redline?
Where did you get it?
doublej is offline   Reply With Quote
Old 04-25-2014, 06:22 AM   #74
No, I had to get a new rotor for my Pro4 4000kv. 2 of the magnets started to pull from the center shaft.
Old 04-25-2014, 08:09 AM   #75
Sounds like you need some DLux axle shafts and knuckles.
Highmark is offline   Reply With Quote
Old 04-25-2014, 08:15 AM   #76
Erik and I have discussed it.. :thumbsup:
Old 04-25-2014, 11:24 PM   #77
Get a hold of Creeperbob he did up a set of titanium rears for me at the same time i started this axle madness. Curious on your gearing/slipper clutch assembly ??? I dont mind destroying stuff from driving like an idiot its the breaking crap when im not.
Old 04-28-2014, 09:51 AM   #78
Erik D_lux's Avatar
I have just a few SCX/AX10 housings with the 13mm bearing in stock now. I would be willing to do more if these go well. If they dont,... get them while they last... LOL
Old 04-28-2014, 01:23 PM   #79
Order placed for two more. Thanks Erik.
ninja turtle is offline   Reply With Quote
Old 04-28-2014, 04:52 PM   #80
Can you hold on to 2 scx10' cases for a couple days? Was gonna buy some at a local hobby shop but yours after the mod are $10 cheaper
*Oops. The way it was worded I assumed it was two cases for $20. I'll have to dig a little deeper in my pockets for the next parts order.
djjiz is offline   Reply With Quote
Wraith/AX10/SCX10 pinion bearing mod - Similar Threads
AS-3 Bearing mod Kaptain Axial SCX-10 27 04-08-2014 11:43 PM
Bearing mod chessmaster Axial XR10 10 03-17-2011 02:45 PM
9mm bearing mod losichris Axial XR10 21 10-07-2010 07:18 PM
Pinion Bearing Walk? sickfab HPI Wheely King 12 08-29-2007 01:28 PM
You may edit your posts
