Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Wraith/AX10/SCX10 pinion bearing mod
Old 04-28-2014, 06:58 PM   #81
Wanna get? Gotta want.
Erik D_lux's Avatar
Default Re: Wraith pinion bearing mod
I edited the website to clarify its for 1 housing. Thanks for the feedback.
Erik D_lux is offline   Reply With Quote
Old 04-30-2014, 09:35 AM   #82
Default Re: Wraith/AX10/SCX10 pinion bearing mod
I ordered up a pair last night.
jopes is offline   Reply With Quote
Old 05-08-2014, 02:14 AM   #83
Originally Posted by winnerone23 View Post
I'm running axial hd gears with stock ratio now. I ruined a handful of gears before switching to the modded axles. I tried bearings and bushings before. And that was just with a 13.5t redline on 3s.
I'm running fasteddie bearings thru out.
I don't consider anything a weak spot, not when I'm behind the wheel!
I just like destroying shiz and this is my rig for just that.
Got my VP vvd V2 (5mm) stub shafts today. Can't wait to get my new rotor so I can put them thru there paces!
Next will prolly be some lockedup rc OT shafts for the rear, once they come out. I should be pretty solid then.
Are you running normal rotation (rear ring gear on left) or reverse (rear ring gear on right)? I know theoretically it shouldn't matter.....
mikespeed6 is offline   Reply With Quote
Old 05-25-2014, 07:46 AM   #84
Just ordered a couple of those for a Dingo with a ROC412 i'm started modifying, we'll see how those will hold up
Pabust is offline   Reply With Quote
Old 05-29-2014, 03:38 AM   #85
Do I win!?
OG 16mm bearing mod. Pro4 4000kv on 4s..
winnerone23 is offline   Reply With Quote
Old 05-29-2014, 06:13 AM   #86
How long before the ax/scx housings are back in stock? Thanks.
ninja turtle is offline   Reply With Quote
Old 05-29-2014, 06:16 AM   #87
Do I win!?
nope !!
mine just did the same thing !!
the DMG is offline   Reply With Quote
Old 05-29-2014, 07:19 AM   #88
Erik D_lux's Avatar
Do I win!?
YES! You win the chance to run the NEW latest and greatest 13mm housings!
Shouldnt be long. I hope to have a large batch of AX/SCX along with the AR60 here very soon.
Old 05-29-2014, 03:16 PM   #89
Originally Posted by the DMG View Post
nope !!
Well I posted first! lmao...
Pics or it didn't happen....
Old 05-29-2014, 03:37 PM   #90
Im glad I got mine after r&d! I installed them last weekend and so far so good. No shims needed, the mesh is perfect and there is zero play in the output shaft. Running 1/8th scale brushless and that bearing was for sure the weakest link on my setup. Thanks for making these available!
colebz is offline   Reply With Quote
Old 05-30-2014, 01:41 PM   #91
Kind-a like Big Foot !! - no pic - isn't real !!
@ least my housing is nice & clean
still the BEST way to go - i know the stock bearing wouldn't last half as long,
ordering another one ASAP - THX Delux
Old 05-30-2014, 08:14 PM   #92
binaryterror's Avatar
Could this mod be done to Vanquish Aluminum ar60 housings?
I mean it'd be easier for VP to fix, but you always have the best ideas, products and services
binaryterror is offline   Reply With Quote
Old 05-30-2014, 11:58 PM   #93
Pretty sure I read that the material was too thin but I could be wrong.
djjiz is offline   Reply With Quote
Old 06-02-2014, 08:47 AM   #94
Erik D_lux's Avatar
I could, the problem is liability. When I am making only a couple of dollars on a mod that could potentially ruin your housing, its just not worth the risk. Sorry.
Old 06-08-2014, 06:24 PM   #95
Checked your site and it lists the AR60 as out of stock. Any idea when you expect to have more?
Sent from my SHV-E330K using Tapatalk
Trisk is offline   Reply With Quote
Old 06-09-2014, 08:39 AM   #96
Erik D_lux's Avatar
Sorry guys, I dont know what is going on. I have had housings on order for almost 3 weeks. I was told I would have them last week and nothing.
No matter what, I will have some for sale and on my website on Friday, at the latest.
Thanks for being patient.
Old 06-13-2014, 08:03 AM   #97
Erik D_lux's Avatar
Now in stock and shipping as promised!
I have SCX housings with the mod.....
I have AR60/Wraith housings with the mod....
And now, I have Axial EXO housings/bulkheads with this mod! The EXO housing could really help out the guys running an EXO front end on their crawlers. I only have a couple to see how they go. If they are something you guys want, its something I can keep in stock.
Old 06-22-2014, 07:07 AM   #98
Subscribing for future reference.
My yeti will definitely need this. .
I'm hoping the Yeti front housing will be the same as the Exo.
gbean is offline   Reply With Quote
Old 06-23-2014, 10:06 AM   #99
Natedog's Avatar
Great news and I bet the Exo front housing is same as Yeti!
Old 06-23-2014, 10:07 AM   #100
Erik D_lux's Avatar
Hopefully it is. I bet all the Yeti guys and even the WREXO guys would really benefit from this mod.
Wraith/AX10/SCX10 pinion bearing mod - Similar Threads
AS-3 Bearing mod Kaptain Axial SCX-10 27 04-08-2014 11:43 PM
Bearing mod chessmaster Axial XR10 10 03-17-2011 02:45 PM
9mm bearing mod losichris Axial XR10 21 10-07-2010 07:18 PM
Pinion Bearing Walk? sickfab HPI Wheely King 12 08-29-2007 01:28 PM
You may edit your posts
