Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Dlux custom knuckles V2!
Old 07-03-2014, 04:26 PM   #101
GOT SCALE ?
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
Default Re: Dlux custom knuckles V2!
Originally Posted by Erik D_lux View Post
Yep, they are made to work with the XR/Wraith stub shafts.
Yours were shipped yesterday so you should have them soon. Thanks for the order!
No thank you Erik! .. .. these knuckles are a great ideas and good value. I got excited when I saw your "brass knuckles" for the first time I knew I needed a pair for a brand new 2.2 scale build.
Stormin2u is offline   Reply With Quote
Old 07-16-2014, 02:00 PM   #102
Wanna get? Gotta want.
Erik D_lux's Avatar
Adding Bully V2 knuckles to the mix!
Specifically for the B2:
  • This fixes the short steering arm issue. With the longer steering arms you will have A LOT more steering power and less stressed steering components.
  • Adds the ability to add much more knuckle weight including the loaded dice knuckle weights. Loaded Dice Knuckle weight add ons
  • Better/bigger bearings than stock. (2-8x16)
  • The knuckles have the ability to convert from 8* to non 8* just by moving the screw holes in the arm.
  • This is a knuckle and a knuckle weight all in one. Much more manageable design to deal with rather than multiple separate pieces.
  • Bearings for king pins.... super smooth, no slop!
  • Ultra-light all the way to decently heavy by using Delrin, 7075 or Brass.
  • Due to the design, these have an extreme amount of strength at the arm. No more bent or broken arms.
  • Perfect steering arm geometry using zero ackerman.
  • Built in steering stop holes on the back side! Now you can protect your setup with an easy to set and use setup.
  • Optional slug holes to adjust your weight even more
Erik D_lux is offline   Reply With Quote
Old 10-06-2014, 01:32 PM   #103
CODYBOY's Avatar
Hi Erik, Has anyone asked you about making these for the Vettera ascender? I would be interestd!
CODYBOY is offline   Reply With Quote
Old 10-07-2014, 10:58 AM   #104
Erik D_lux's Avatar
No, never really even heard of it.
Drum up some interest and I would be happy to look into it.
Old 10-07-2014, 05:14 PM   #105
CODYBOY's Avatar
Really??? OK, I mispelled it, sorry!!!! Vaterra Ascender 1986 Chevrolet K-5 Blazer. The new 1.9 scale truck that is going to make Axial change the way they design scale rigs.
Old 10-08-2014, 08:27 AM   #106
Erik D_lux's Avatar
Sorry, I dont follow the scale scene much.
If I see some interest I will be happy to look into it.
Old 10-29-2014, 11:41 AM   #107
Erik D_lux's Avatar
Adding the Yeti knuckles to the line up! Please check my website or post #1
Old 12-16-2014, 10:04 AM   #108
DeadlySwan's Avatar
By the way..... if anybody has a car that they want these to work on, you can speak up. The idea is that they will work for almost anything and it wouldnt be that hard to make it happen.
Bully2
Losi comp crawler
Looks like both the above could happen, I just need interest.
Is there any other cars that could use these? Maybe there are some older axles where parts are not available anymore?
I still have my Losi i want to make a 2.2s out off. Can you make these for the losi yet?
Whats the best bearing set up for a Berg? 16mm front and rear? 16mm front and 22mm rear? Running OFNA shafts
DeadlySwan is offline   Reply With Quote
Old 12-17-2014, 08:27 AM   #109
Erik D_lux's Avatar
I could make a set and would..... nobody has cared about the LCC though. I have a LCC stub shaft here. I will take a look today and see what I can figure out. If its easy enough, I will let you know and I can pop some out.
For a 2.2, 16mm bearings is overkill. 16mm may even be overkill for supers and go fast cars but peace of mind on the supers and go fast means a lot too. I have never heard of anybody blowing a 16mm bearing. To put it in perspective, RC4wd used 12mm bearings for the Bully and not a ton of people had issues with those,... except me.
Old 12-18-2014, 08:02 AM   #110
Erik D_lux's Avatar
I did some checking and the LCC version would be easy enough to make. The only hurdle, which would be small, would be to figure out how to attach the knuckle arms to the c hub. It looks like it could be simply achieved by running a 4mm bolt through the arm and hub with a nut on top.
I wont be planning on putting these on my website unless there is some demand. I would be happy to make a one off set for somebody though.
Old 01-23-2015, 12:11 AM   #111
On the Yeti knuckles and OFNA stubs, can you run an open front diff still or do you have to run a locker?
wrightcs77 is offline   Reply With Quote
Old 01-23-2015, 06:50 AM   #112
Erik D_lux's Avatar
An open diff option should be here within 2 weeks.
Old 01-28-2015, 10:11 AM   #113
DLux, any hint on price of the open diff separately if I buy the spool set up now? Not sure if I can wait
Old 01-28-2015, 10:37 AM   #114
Erik D_lux's Avatar
The open diff outputs should be approx $25.
Old 01-29-2015, 12:21 PM   #115
Erik,
About to place an order for OFNA axles, aluminum hubs for Yeti. Any idea on how much weight is saved on the knuckle when you drill the slug holes? Trying to keep it as light as possible. Trying to decide if it is worth the $20 to have slug holes drilled to save weight up front.
Old 01-30-2015, 08:06 AM   #116
Erik D_lux's Avatar
Good question!
Looks like the slug holes save 7g per knuckle. I dont have a narrow one to check, but math says a non slug narrow 7075 OFNA knuckle is 27g, slug narrow 7075 20g.
Old 03-24-2015, 01:18 PM   #117
Hey Erik.....any chance of selling those Ofna 7075 zero offset hubs individually? I didn't see them on your website
bquin is offline   Reply With Quote
Old 03-25-2015, 08:29 AM   #118
Erik D_lux's Avatar
Yeah, I have stainless 0 offset. You can go to dluxfab.com/products --> axles/axle shafts ---> Ofna hubs
Shows a picture of the delrin but 0 offset is an option when you buy.
Old 04-19-2015, 02:36 PM   #119
Hey Erik - about to pull the trigger on a set for my bully2, just curious how many .100 rings will fit if I'm running your beadlocks?? Thanks
Realize you need to know the hub width .720 with a 1/16 spacer
crawlinghulls is offline   Reply With Quote
Old 04-20-2015, 08:09 AM   #120
Erik D_lux's Avatar
Hey,
FYI, RC4wd is out of stock on shafts so that pretty much means I am also, until they get some more.
With a .720 hub and 1/16 spacer on an Axial style stub shaft, you should be able to fit 5/6 .100 rings.
Let me know if you have more questions.
Dlux custom knuckles V2! - Similar Threads
Dlux custom knuckles Erik D_lux Axles, Trannys, T-case 34 01-07-2014 12:14 PM
DLUX Knuckles for EVERYTHING ! Harvo EnRoute Berg 21 12-05-2013 10:38 AM
You may edit your posts
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
