03-02-2014, 08:09 AM | #1 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
| Snipers Fab Shop Prodigy Trans Prodigy Transmission Will come complete ready to bolt in Carbon fiber side plates and adjustable mounting plate bearings,and RC4WD XR gears. Titanium adjustable output shaft The unit pictured has G10 side plates and stock gears, production versions will be carbon fiber plates and lightened hardened gears. you will need to remove a small amount of material for the final gear to clear if using the most forward mounting location The trans is designed to work in the new Turbotech Prodigy chassis, using the stock skid, turned around backwards in the chassis, you will also have to use button head hardware on the front upper link mounts and put the bolts in from the inside of the chassis and the nuts on the outside of the chassis for the motor and driveshaft to clear them. The titanium output shaft also is adjustable, it has a machined flat on the entire shaft, and can be slide forward of aft to aid in driveshaft clearance and angle. $140 shipped CONUS priority I will also be selling the servo/battery mount from the build thread. Snipers Prodigy |
03-03-2014, 11:50 AM | #2 |
Pebble Pounder Join Date: Nov 2011 Location: Oregon City
| Re: Snipers Fab Shop Prodigy Trans
Are these ready to ship?
03-03-2014, 02:03 PM | #3 |
I am putting a few together now, should be able to ship by the weekend
03-04-2014, 02:26 PM | #4 |
Rock Stacker Join Date: Aug 2010 Location: truckee
Is there any way to get the g10 version with unlightened gears. I don't care about weight.
03-10-2014, 02:12 PM | #5 |
I wanna be Dave Join Date: Aug 2007 Location: JERSEY BOONDOCKS
Awesome Rick! I can't wait to get one of these running in my sporty!
03-12-2014, 11:54 PM | #6 |
Just curious, is the notch in the adapter plate to allow the lower link rod end to clear?
03-15-2014, 06:53 AM | #7 |
| Re: Snipers Fab Shop Prodigy Trans |
Snipers Fab Shop Prodigy Trans - Similar Threads | ||||
Snipers Prodigy | sniper | Axial AX-10 Scorpion | 95 | 02-14-2015 02:33 PM |
Snipers Fab Shop carbon chassis braces | sniper | Chassis and Suspension | 15 | 01-21-2014 05:25 PM |
Snipers Fab Shop wheel lightening | sniper | Tires and Wheels | 17 | 10-01-2013 11:49 AM |
Snipers Fab Shop | sniper | Vendors Market | 13 | 07-06-2013 02:14 PM |
Snipers Fab Shop carbon Servo clamps | sniper | Vendors Electronics | 2 | 05-26-2013 04:11 PM |
