03-12-2016, 01:16 PM | #261 | |
| Re: ToyZuki's Fabrication Low Center of Gravity Motor Mount Quote:
But I would think this chassis setup was more than likely conceived to get the weight forward for better crawling performance (since most crawlers climb in forward). On a rock-racer, you might not be 'shooting yourself in the foot', but since most here are more about the crawl, it would make sense that most are going to install it motor-forward. But don't let that deter you. Go for it! BE the innovator! And post up a build thread, we'd love to see the direction you take it. | |
03-12-2016, 06:45 PM | #262 | |
Quarry Creeper Join Date: Feb 2008 Location: chico
[IMG][/IMG] | |
03-12-2016, 06:45 PM | #263 |
03-15-2016, 09:45 AM | #264 |
Rock Stacker Join Date: Dec 2013 Location: MN
Sent PM about the mount for a flat chassis.
03-16-2016, 12:52 PM | #265 |
Hey sorry to bother you but I'm kinda confused abut the top shaft that I put in your divorce kit. In Harley's video he uses the shaft with the two flat sides instead of the pin style shaft. Well I have three of the flat style shafts and none are as long as the one Harley is using I have the same slipper as far as I can see. But even with only one spacer there's not enough shaft for the slipper plates and spur on the flat part of the shaft. And then there's not enough room for the spring. Is there e two different length non pin style top shafts?
03-16-2016, 12:56 PM | #266 | |
RCC Addict Join Date: Nov 2008 Location: Central, WA
03-16-2016, 01:24 PM | #267 |
So there is two flat spot styles?
03-16-2016, 01:58 PM | #268 |
yeah I know how to make it work without the slipper but for what I'm doing I kinda want a slipper. The only place I can find the shaft in the video is on Amazon. Sold out on axails site and A main doesn't have em. On a side not the top shaft for the axail two speed fits with a slipper
03-16-2016, 02:49 PM | #269 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
I used AX31149 - It's super long.
03-16-2016, 03:20 PM | #270 |
| Re: ToyZuki's Fabrication Low Center of Gravity Motor Mount |
03-16-2016, 03:28 PM | #271 |
RCC Addict Join Date: Aug 2012 Location: Philippines
I had to switch to the new dual pad slipper because the old one wouldn't clear the servo on the VP CMS plate.
03-16-2016, 03:41 PM | #272 |
| Re: ToyZuki's Fabrication Low Center of Gravity Motor Mount $7 Free shipping: Axial Racing AX31149 Axial Slipper Drive Gear Shaft 5x54 5mm | eBay |
03-16-2016, 07:29 PM | #273 |
I just bought the 2 speed axial shaft and cut it shorter actually might be a good option for some people because you can make the shaft a lot longer and put a hole in it down closer to the end of the motor-can for custom situations. They had it in stock it worked for $8, and I wanted to put the dang thing together so bam! Lol
03-16-2016, 07:33 PM | #274 |
Also instead of being retained by the driveline it has a c clip which I hope doesn't turn out to be a weak link.
05-09-2016, 03:47 PM | #275 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
pm sent about the G10!
05-27-2016, 03:51 PM | #276 |
Quarry Creeper Join Date: Aug 2014 Location: Orange County
What is the cost of the g10 vs the aluminum mount? Sent from my SM-G920T using Tapatalk |
05-27-2016, 04:36 PM | #277 |
RCC Addict Join Date: Aug 2005 Location: SoCal
06-02-2016, 07:17 AM | #278 |
Newbie Join Date: May 2016 Location: Houston
I shot you a PM about ordering a chassis. Just wanted to see if it went through. Wrong product. Will post under chassis. Thanks! Last edited by Manchild; 06-03-2016 at 06:55 AM. |
08-11-2016, 07:36 PM | #279 |
Newbie Join Date: May 2006 Location: LONG BEACH
Hey just wanted to post up my install. Toyzuki shipped mine out the next day, which is great for a custom part. With a little massaging everything clears. Using Vanquish panhard/servo mount. Custom 3 links for a 12" wb I don't know how to post a photo at the moment |
08-13-2016, 08:25 PM | #280 |
Just need to mention my toyzuki setup on KLR's with a mid mounted battery under the tranny is extremely capable. It can crawl lines many 2.2's struggle with. It's been some work and tuning time, but it's my go to for just about anything. Sent from my SPH-L720 using Tapatalk |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axles-trannys-t-case/486740-toyzukis-fabrication-low-center-gravity-motor-mount.html | ||||
| Harley Designs | This thread | Refback | 01-31-2015 07:59 PM |
ToyZuki's Fabrication Low Center of Gravity Motor Mount - Similar Threads | ||||
Installing a "ToyZuki's fabrication Motor Mount" | ToyZuki | General Scale Talk | 70 | 03-23-2020 10:14 PM |
level3 low center of gravity motor mount | drkuhar | HPI Wheely King | 17 | 02-22-2015 10:55 PM |
Low Center Of Gravity | weston6969 | Redcat Crawlers | 5 | 01-23-2010 04:27 PM |
Better center of gravity? | 66sprint6 | Axial SCX-10 | 26 | 11-20-2009 02:28 PM |
center of gravity | johnathan c | Newbie General | 5 | 07-13-2007 11:50 AM |
