Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: Loaded Dice Knuckle weight add ons
Old 04-21-2014, 08:09 AM   #1
Wanna get? Gotta want.
Erik D_lux's Avatar
Default Loaded Dice Knuckle weight add ons
Short and sweet for now so I can avoid answering the same question in PM over and over. As of now, there are too many options so I think I will just take orders through PM.
Please be patient. There are a million options and ways to set these up. Also, since there are a million different versions of wheel faces available, I will have to make them to order. If youre the impatient type, you may want to pass on these.
I need to know:
Delrin or Brass weights
Wheel face style
Wheel face color/material
To run these weights, you MUST run a Dlux knuckle and the NEW Dlux wheels.
Erik D_lux is offline   Reply With Quote
Old 04-21-2014, 08:09 AM   #2
Erik D_lux's Avatar
Default Re: Loaded Dice Knuckle weight add ons
I will have 2 versions of weight holders.
First is a Delrin holder (lower cost, not as much overall weight) as seen in my sporty thread Dlux Sportsman build I dont have an accurate weight just yet but should be 4.5-5oz fully loaded not including the weight of the knuckle.
$30 for the holders, $47 for the tungsten weights (16pcs)
The second version is the brass version (heavier and more expensive) as seen in the Berg section Dlux Berg Build I believe these weights came in close to 6oz full of tungsten.
$80 for the holders, $47 for the tungsten weights (16pcs)
Old 04-21-2014, 08:09 AM   #3
Erik D_lux's Avatar
I top off the brass weight holder with another big brass ring. This thing weighs a full 1.7oz by itself and should get you really close to 8.5oz fully loaded with the brass holders and full tungsten weights
$30 for the pair.
Old 04-21-2014, 08:09 AM   #4
Erik D_lux's Avatar
Wheels.....
Due to the custom nature of these wheels there will be no exchanges or refunds.
I can make the face from G10 or Carbon fiber. I only went with G10 to get some color on my car (sick of full CF look).
Black G10 set of 4 $60
Any color you want G10 set of 4 $75 See here for colors G10 Colors & Textures - AKS™ Alpha Knife Supply G10 Material Colors. Maybe a wait time if I have to order the color in.
Carbon fiber set of 4 $80
All wheels will be shipped as 3/4" wide wheels. I measure BETWEEN the tire beads. I can go larger on special request and can do 5/8 wide too. Be aware that 5/8 version is harder to setup and fit
Face styles (in order below):
5 Star
Rising sun
V cut
D cut
Slug
Stars
Old 04-21-2014, 08:20 AM   #5
Erik D_lux's Avatar
How to assemble the wheels:
Check this YouTube video for instructions on how to install the weights and also how to assemble the wheels. Starting at 3:55
https://youtu.be/1VbVoj3RiFo
Old 04-21-2014, 08:56 AM   #6
Very nice. Are the tungsten weights the same dia. as the ones offered by Derby Monkey?
saniel68 is offline   Reply With Quote
Old 04-21-2014, 10:03 AM   #7
Could you show how the wheels work or go together? Is it like a bead lock but from the inside or are they glue on?
Off topic, Yay post 50. I am not a freaking newbie anymore
Session is offline   Reply With Quote
Old 04-21-2014, 10:29 AM   #8
Erik D_lux's Avatar
Yep, they are the Derby weights.
They are all glue on, inside and out. I will try to get some pics of how they work when I get a shot. You will need to slightly modify your tires too which will make them so they can never be used as a bead lock again, only glue ons.
Old 04-22-2014, 05:48 AM   #9
Those brass holders with the Tungsten weights are pure sex.
Wicked Monkey is offline   Reply With Quote
Old 04-24-2014, 05:52 PM   #10
Still waiting Sir.........I have some guesses but now its starting to gnaw at my little brain
Old 04-24-2014, 07:15 PM   #11
It's easy once you have them in your hands. I don't think he wants to show too much on line until you get them because they are pretty proprietary.
Harvo is offline   Reply With Quote
Old 04-25-2014, 09:41 AM   #12
Mr D said he was going to post some pic's so I had no idea they were classified.......There is no way another vendor would make something almost exactly the same would they?
Old 04-25-2014, 03:39 PM   #13
Erik D_lux's Avatar
I am not too worried about it. My biggest problem right now is that I am consistently trying to get caught up. Just a matter of priority and orders have a bigger priority than these pictures. Sorry. I promise I will get to them ASAP, I have have to since the first batch of these weights shipped today.
Old 07-11-2014, 01:39 AM   #14
Question. I got The brassholder with tungsten wheights. But cant get The wheights in the holes they are slighty to big. So how do i get them in place? Heat and freeze?
gooserools is offline   Reply With Quote
Old 07-11-2014, 08:46 AM   #15
Erik D_lux's Avatar
They are made for a press fit. When I install them I use a hammer and a punch to drive them in. I hope that helps.
Old 10-21-2014, 09:06 AM   #16
just a suggestion freeze the tunsgton and place the brass in hot water,they will come together snuggly and when at room temp are tight. work for me
Drew3627 is offline   Reply With Quote
Old 12-23-2014, 09:40 AM   #17
same wheel.system as I got,,,
The carbonfiberwheels that was held together by a nut is what came along the axels when I bought em,,,,I also got some G10 with 6 holes like the revolver consept...
FLOKI-81 is offline   Reply With Quote
Old 12-23-2014, 04:06 PM   #18
does the loaded dize weightsystem fit in youre carbonfiber D cut 2.2 wheels,,and V cut wheels,,
And do you have other carbonfiber wheels that the loaded dize fit inside,,
PS,,, Have a merry merry X-MAS!!!!!!!
Old 12-24-2014, 06:33 AM   #19
Erik D_lux's Avatar
I think all of your questions have already been answered in this thread? If not, let me know which ones you do not see.
Merry Xmas to you, Floki.
Old 12-25-2014, 08:50 AM   #20
Do you make the V cut spokes in carbonfiber???
Loaded Dice Knuckle weight add ons - Similar Threads
show me some bolted or brazed scx10 frame mods/add ons murdock Axial SCX-10 27 01-22-2016 06:15 PM
Add on weight rings for vanquish knuckle weights knobbytrav Axial AX-10 Scorpion 3 12-28-2011 11:15 PM
New add ons to my WK Pete720 HPI Wheely King 4 01-24-2009 11:24 AM
You may edit your posts
