01-22-2015, 11:27 AM | #21 |
Rock Crawler Join Date: Feb 2007 Location: Crawling Around
| Re: GCM A-13 MetalHead Axles Up Again-New Info
Yep, Tracking says: December 16, 2014 , 11:15 am Available for Pickup CHICAGO, IL |
01-22-2015, 12:03 PM | #22 |
Moderator Join Date: Jan 2004 Location: chicago
man... go figure its a usps issue. and also, just want to say ive never had nothing but awesome customer service from the dudes at gcm. just for whatever reason the downtown chicago usps always seems to lose my out of country packages... Last edited by badhoopty; 01-22-2015 at 12:36 PM. |
06-24-2015, 07:03 PM | #23 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
I just bought these axles love them confused on the panhard mount that slides on I'm used to the bracket being on the side closest to k uckle with these axles it would have to be closer to the pumpkin does this effect anything
06-24-2015, 07:25 PM | #24 |
Ya, just get a link setup that fits and try to setup the frame side bracket that keeps the link flat ish. And parallel with your steering servo pushrod.
06-24-2015, 07:34 PM | #25 | |
| Re: GCM A-13 MetalHead Axles Up Again-New Info Quote:
Sent from my SM-N910T using Tapatalk 2 | |
06-24-2015, 07:36 PM | #26 |
Ah, ok. Got it.
06-24-2015, 07:37 PM | #27 |
Just as long as it's ok closer to the pumpkin cause just wasn't used to that before that's all Sent from my SM-N910T using Tapatalk 2 |
06-24-2015, 07:46 PM | #28 |
Sure. On our TerraMod housings we have the panhard mount right on top of the offset pumpkin, so Ya it's good.
06-24-2015, 08:08 PM | #29 |
Ya saw that just figured I post and see but thanks for the info Sent from my SM-N910T using Tapatalk 2 |
07-15-2015, 07:37 PM | #30 |
Well I got my truck built with these axles love them but I changed up the panhard mount instead of it mounting to the inside of the link closer to the pumpkin with it like that I couldn't get the 3 link to work like I liked and was causing massive bumpsteer so what I did was cut down the VP chub and moved the panhard bracket on the other side of link mount closer to the chub and bam good to go Sent from my Nexus 6 using Tapatalk |
09-02-2015, 05:47 AM | #31 |
Pebble Pounder Join Date: Oct 2006 Location: belgium, roeselare
Hello, these can be built as rear steering wraith axle, right? i need something for a 4ws monster truck.
09-02-2015, 07:38 AM | #32 |
That's true. With the front axle assembled up side down there's a rear steer option
09-03-2015, 03:50 AM | #33 |
when is the next production run? or can i get them whenever i want?
02-25-2017, 02:37 PM | #34 |
fwiw i think you guys would have a hit if you made a run of steel metalheads for scx10.2 axles.
GCM A-13 MetalHead Axles Up Again-New Info - Similar Threads | ||||
GCM A-13 All Aluminum Wraith MetalHead Axle Housings | Generis | Axles, Trannys, T-case | 58 | 06-19-2014 08:02 PM |
GCM MetalHead Axle Pre-Order Now Open | Generis | Axles, Trannys, T-case | 99 | 04-19-2013 12:30 PM |
VP Currie axles or GCM Metalhead axles for scx10 | Swamp Dowg | Axial SCX-10 | 8 | 03-31-2013 11:03 AM |
