12-31-2014, 04:05 PM | #21 |
Quarry Creeper Join Date: Feb 2008 Location: The Schwa
| Re: Holmes Spools for Axial (and HPI) |
12-31-2014, 07:30 PM | #22 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
I have a quick question. What is the difference between the phased and non phased versions and what is the benefit of the phased version?
01-11-2015, 02:07 AM | #23 |
Inventory updated, and we also have aluminum CrawlMaster spools in stock. Pic on the site is not updated as of this moment. Now all spools we are making are in-phase to reduce drivetrain harmonics. The original batch was at 90 degrees out of phase to increase the strength a bit, but since so many people are pushing for fast these days we are just going to make in-phase spools from now on. |
01-11-2015, 08:05 AM | #24 | |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: Holmes Spools for Axial (and HPI) Quote:
Order placed, thanks. I want the in-phase for my comp crawler, not my go fast. I like the way it bounces up and down, together, when the wheels are turned applying some speed, instead of the left to right, back and forth bouncing that the offset 90* does. | |
01-14-2015, 03:40 PM | #25 |
Are you able to ship these first class? Shouldn't be $7 to ship a few spools... I sent a email with no reply so far.
01-14-2015, 04:29 PM | #26 |
At the moment we don't use first class. 99% of what we ship contains electronics. When I started the business we had an extremely high rate of product damage with first class, the longer it sits in transit the more likely damage. Spools would be OK though, it would be about $4.50 for two of them. A portion of every order's shipping cost gets paid to my packager as a bonus, which makes him work extremely fast and is why there is a small handling fee on every order. Because of the way our site calculates shipping, it would be fastest and easiest to order as normal and ask for first class. We will refund the difference when it is processed. Who or how did you email? I'm not seeing anything in the last few days from you. |
01-14-2015, 04:50 PM | #27 | |
I used the contact form on your site. | |
01-14-2015, 05:10 PM | #28 |
We have been having some issues with that not always coming through and are going to remove it and use our own interface, sorry about that. Email jonathan@ directly or just place the order and put a note in the text box thingy.
01-14-2015, 08:09 PM | #29 |
Newbie Join Date: Jun 2014 Location: Fort McMurray, Alberta
Should you use the little gasket that goes between the gear and the locker with these spools or is there no need?
01-14-2015, 08:14 PM | #30 |
01-14-2015, 08:55 PM | #31 |
I designed these to have stock spacing without the gasket.
01-14-2015, 11:17 PM | #32 |
Great thanks
02-05-2015, 06:58 PM | #33 |
Just got mine tonight. It was a interesting install. I have vvds in my axles and one side went into the spool just find and the other side wouldn't go in so I made it go in with a rubber hammer. Bolted it up and gear mesh was really tight...so used heat, wd40, and a rubber hammer to get it out grinded down the tang a little bit now it slids in and out without much slop. just thought I'd share. They are great spools besides that. NOt sure if its a vvd issue or spool issue. Needless to say my fingers hurt. I will wait to do the rear tomorrow. |
02-05-2015, 07:29 PM | #34 |
VVDs have slightly thicker tangs than Axial ones. I've been working on a design that can accomodate them both, but I don't have the right tool holders to make it possible in my machine. Yet... You may try sanding the edges where the tang transfers from flat to round. That is where the interference is on VVDs. It isn't the tang width anywhere but just right on that edge. |
02-05-2015, 08:23 PM | #35 |
Yeah I got it to work fine. Would have been nice to know before I forced it in there and killed my hands getting it out and filing it down a bit on the edge. All good now. |
04-06-2015, 05:38 AM | #36 |
Pebble Pounder Join Date: Feb 2014 Location: Sweden
Tried mounting my hh spools yesterday and the side of the spool that holds the bevel gear is just too tight. The other side worked as described - with a little wiggle. What should I do about this? I could possible hammer the shaft in and try get it out with some gripper to make the hole big enough? I tried stock wraith shafts, universals and VP vvds. Both spools I have is like this. |
04-06-2015, 09:12 AM | #37 |
Sand the shaft a bit to knock the edge of the tang off. You won't need to make the tang thinner. Thanks for the feedback on the fitment, if a little sanding doesn't get the shafts in we will get you traded out.
04-06-2015, 11:00 AM | #38 |
| Re: Holmes Spools for Axial (and HPI) Ok thanks I'll give that a try. Will let you know how it goes.
04-08-2015, 02:41 AM | #39 |
| Re: Holmes Spools for Axial (and HPI) Hi again. I tried sanding the edges of the tang slightly. This improved things a little. However when there is about 5mm left of the tang to go in it's completely jammed. I will try put the axle in a wise and hammer the spool onto it. Doing that a few times will hopefully open it up.
04-08-2015, 07:36 PM | #40 |
Rock Crawler Join Date: Oct 2011 Location: Fairfield
Found that the torque master spool isnt a drop in for the centered currie axle. VP has their axle shafts basically touching and the spool isnt a through hole design.
