Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: SDS Axial 8*chub Knuckle Adapters
Old 10-25-2015, 01:45 PM   #1
RcBros Hobbies
RcBro's Avatar
Default SDS Axial 8*chub Knuckle Adapters
I have a bag full of these Brass Adapters for those still needing them!!
(Steel sample for pictures only)
$12.00 a pair, available here:
SDS Customs Brass Knuckle Adapters | RcBros Hobbies
RcBro is offline   Reply With Quote
Old 10-30-2015, 01:59 PM   #2
Default Re: SDS Axial 8*chub Knuckle Adapters
So could I use these with vanquish 8 degree knuckles, vanquish wraith knuckles, and xr10 universals with ssd axles?
Di_Spencer is offline   Reply With Quote
Old 10-30-2015, 02:00 PM   #3
RcBros Hobbies
RcBro's Avatar
I am not familiar with the SSD equipment.
Old 10-30-2015, 02:02 PM   #4
Could I used vanquish 8 degree knuckles, vanquish wraith knuckles and xr10 universals in scx10 axles?
Old 10-30-2015, 02:03 PM   #5
RcBros Hobbies
RcBro's Avatar
These are for adapting just the c hub to the knuckle. You will need to modify the universal.
Old 10-30-2015, 02:08 PM   #6
What would need to be modified?
Sent from my Nexus 4 using Tapatalk
Old 10-30-2015, 02:09 PM   #7
RcBros Hobbies
RcBro's Avatar
The length.
Old 10-30-2015, 02:46 PM   #8
Thats what I needed to know thanks for the help and quick responses.
Old 12-31-2016, 08:56 PM   #9
Do I need a wraith stub shaft to make this work?
limegalodon is offline   Reply With Quote
Old 12-31-2016, 11:35 PM   #10
Yes, the axle must have the wraith length stub not the scx length.
Sent from my SM-G920T using Tapatalk
Old 01-01-2017, 12:09 AM   #11
This question might sound dumb but is the wraith stub shaft from VP fit the super 300s? I only have the scx version
Old 01-01-2017, 12:10 AM   #12
I have no idea. The only way to tell I think is to try it.
SDS Axial 8*chub Knuckle Adapters - Similar Threads
Help me choose the best knuckle and chub demonoid369 General Crawlers 17 06-15-2012 08:37 AM
You may edit your posts
