Go Back   RCCrawler Forums > Vendors > Vendors Market > Axles, Trannys, T-case
Thread: OTVD 5mm stub and 5mm bore steel wheel hexes
Old 04-13-2017, 02:58 PM   #1
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Default OTVD 5mm stub and 5mm bore steel wheel hexes
We are happy to now offer OTVD with a 5mm Stub for the SCX10/AX10 platform.
These are a MASSIVE upgrade to the stock units!
Compared to our standard 4mm stub version:
These do require the use of 5mm straight bore wheel hexes.
You can either drill your own out, or pick up a set of our 5mm Straight Bore Steel Wheel Hexes.
If you already have a set of OTVDs and simply want to upgrade, we have the 5mm OTVD Outer shaft available individually as well.
Thanks for reading!
Locked Up is offline   Reply With Quote
OTVD 5mm stub and 5mm bore steel wheel hexes - Similar Threads
OTVD 5mm stub and 5mm bore steel wheel hexes Locked Up Locked Up RC 5 04-26-2017 10:59 AM
You may edit your posts
