Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Chassis and Suspension
Thread: Question on MSD purchase?
Old 05-12-2008, 10:52 AM   #1
Default Question on MSD purchase?
After looking on the MSD site for weeks, last Saturday I finally found a set of Top Guns. Of course I purchased them without haste, lol. But, now I am wondering. First off, these are what I bought. And of course after the fact I have some questions.
Are these the Axial offset? Do they take the hexes from the Scorpion? I would assume so, but I will not know until I get them. If they are correct, they will be the ones that will rub on the RCP High Clearance Knuckles, right? I also noticed in the MSD page that they had a small run of different offsets that fit these knuckles without modification. How would I know if I got those?
Any help would be appreciated as I know there are a lot of you who run these wheels. thanks in advance all!
Jon
O.C.D. is offline   Reply With Quote
Old 05-12-2008, 10:55 AM   #2
Keep it real
Tanis's Avatar
Just from reading the description on the website, it says the hex is flush with the backside of the wheel for 100% offset, which tells me they will put you at a wider trackwidth than the axials.
Tanis is offline   Reply With Quote
Old 05-12-2008, 11:11 AM   #3
binaryterror's Avatar
Offset will be wider, but I like mine (actually not MSD's) wider now.
They will fit a normal 12mm hex, but the Axial has a nub on it's hex. You can either file/cut the Axial hex flush, or drill out the hole in the wheel. Your call.
binaryterror is online now   Reply With Quote
Old 05-12-2008, 11:13 AM   #4
Damnit, damnit, damnit.
So how much wider are we talking here? 1/4" each side? I know I should know this but the site is limited in info, and I have never put other wheels on mine. This will be comp legal?
Old 05-12-2008, 11:30 AM   #5
RIP Buster
badger's Avatar
Did you ever think about contacting MSD to get the info straight from them?
Moved to the MSD forum.
badger is offline   Reply With Quote
Old 05-12-2008, 11:31 AM   #6
Moving on!!
THnCS's Avatar
Hey Doc, You will be fine with those. I have the same set on my comp rig. You will need to cut the nub off like Binary stated. My track width is at 10 1/4 with these same wheels. I have had no issues. You will love them!!!
THnCS is offline   Reply With Quote
Old 05-12-2008, 11:56 AM   #7
X2 - same as THnCS - just take the 12mm Hex to a sanding belt or disk and take of the nub - you will love em - I run mine with RCP knuckles with no prob.
Yawzer is offline   Reply With Quote
Old 05-12-2008, 08:00 PM   #8
spotting is for 1:1
JOYSTICK's Avatar
DITTO
JOYSTICK is offline   Reply With Quote
You may edit your posts
