| | #1 |
| Est. 2003 ![]() Join Date: Jun 2004 Location: On the Boat to Whore Island
| Servo Crown (TM) Servo Armor (TM) Installation Instructions. Purchase Servo Armor & product info here: **NEW From Reign - The Servo Crown (TM)** OPTION 1: I started with my standard AX-10 servo mounting. This also works with The Reign STL plates and should work for any type of axle servo mount. ![]() I removed the servo & then the servo plate. ![]() ![]() Then I removed the servo mount posts & using a 7/64" drill bit (1/8" is ok but with 7/64" you can thread the 3mm screw through it), I drilled all the way through the existing mounting hole in the stock AX-01 servo post. ![]() I re-mounted the servo plate with out the servo posts. ![]() I then mounted the servo posts onto the servo. ![]() I took the included 30mm mounting screws included with the Servo Crowns, slid them through the holes on the Servo Armor and them treaded them into and through the newly drilled out servo posts. ![]() I sandwiched the servo in between the Servo Crown & the srevo plate and installed the included 3mm lock nut onto the bottom of the servo plate and snugged down the nuts. ***WARNING... Do not over tighten the assembly you may damage your servo!!! Reign Products will not be responsible for any damage the may occur*** ![]() ![]() Installation complete. ![]() ![]() OPTION 2: You can also use ShooGoo to mount these onto a servo. I did just this on my Super crawler and it hold GREAT! Note: Reign Products will not be responsible for any damage the may occur during the assembly or in the use of any of its products. Last edited by PinchFlat; 07-23-2008 at 12:15 PM. |
| Sponsored Links | |
| | #2 |
| MWRCA'er ![]() Join Date: Apr 2004 Location: Byron, IL
| Nice! simple and effective also doubles as a heatsink. |
| | #3 |
| | #4 |
| Pebble Pounder Join Date: Feb 2006 Location: Evanston
| great idea ,Will you be offering any other designs? |
| | #5 |
| I have some others in mind but those will be later. |
| | #6 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| Looks like the castle in Zelda. |
| | #7 |
| I was thinking the BatMan Emblem |
| | #8 |
| whatever! ![]() Join Date: Jun 2005 Location: The bunker
| I was thinking...... Flaming Fag Tent. In a good way.... |
| | #9 |
| Other than using the Axial servo mounts here are also a few others that may work with the Servo Crowns: http://www3.towerhobbies.com/cgi-bin...?&I=LXRUX2&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXJJ29&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXEUC0&P=7 http://www3.towerhobbies.com/cgi-bin...&I=LXTDB7&P=ML http://www3.towerhobbies.com/cgi-bin...?&I=LXMVW3&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXMVW4&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXPLX8&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXPLX9&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXTWM9&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXTWN0&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXUTT1&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXNZF4&P=7 http://www3.towerhobbies.com/cgi-bin...?&I=LXLUA3&P=7 Last edited by PinchFlat; 06-06-2008 at 12:18 PM. |
| Thread Tools | |
| Display Modes | |
