Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Chassis and Suspension
Thread: The Kamikaze Kustoms Zero
Closed Thread
Old 06-07-2008, 11:01 AM   #1
Kamikaze's Avatar
Default The Kamikaze Kustoms Zero
The Zero
[LEFT]
Specificaly designed to optimize the new OCM/Berg axles the Zero is the first OCM/Berg specific chassis on the market. To keep cost dow the chassis uses the stock chassis spacers and hardware.
The suspension is setup to minimize axle swing and steer. Longer rear upper links are used to clock the rear motor up out of the way.
Most shock lengths can be used but I recomend the JP customs 90mm shocks, they fit the outer hole for a 3.25" belly clearance and just the right amount of articulation. A longer shock can be used as well, depending on the amount of ground clearance you desire.
The chassis utilizes TCS bent axial lower links for a 12.375" WB. A variety of upperlinks can be used depending on what squat/anti squat numbers you want. Jato and revo turnbuckles will be sufficiant. However the stock links can be used though they are not recomended without swappin to traxxas rod ends. The stock rears can be bent to give a legal W/B.
I also will offer an optional servo dig/electronics tray. It will be pre-drilled with a slot for a micro servo and holes for the dig switches. This will provide front and rear kill switches on 1 channel.
An 1100mah 3 cell maxamps battery fits very nice on the skid plate of this chassis.
http://media.putfile.com/The-Zero
ALL PURCHASES ARE THROUGH KAMIKAZEKUSTOMS.COM
Kamikaze is offline
Old 06-07-2008, 11:26 AM   #2
OCCUPY RCC!
dezfan's Avatar
Congrats man, good luck w/ the chassis!
dezfan is offline
Old 06-07-2008, 01:58 PM   #3
Kamikaze's Avatar
That is a hand made proto servo tray, the cnc'd version is much slicker.
(happy now????)
Kamikaze is offline
Old 06-07-2008, 02:21 PM   #4
Sign me up for a chassis and electronics mount please.
Hellbilly is offline
Old 06-07-2008, 02:50 PM   #5
Mic
How about one without the rising sun? Maybe one with Stars and stipes
Mic is offline
Old 06-07-2008, 02:56 PM   #6
Kamikaze's Avatar
So that would be like asking for some nike's and asking for an adidas logo on them.....
Kamikaze is offline
Old 06-07-2008, 02:58 PM   #7
I'll take one with the electronics plate. I can't wait to get mine!
chrisjlittle is offline
Old 06-07-2008, 03:26 PM   #8
Location: at the bench of the up 'n coming '79 ford crew cab
look sharp man! Mic, what kind of question is that? i mean seriously he is the Kamikaze! its what he wants and i think its fawking killer with the rising sun on there!
clod & bruiser is offline
Old 06-07-2008, 03:55 PM   #9
Mic
Without going to far into it and to each there own. I am am just proud to be an American It was simple question. This looks like a great product, one I would by. If you have a problem with my above statement message me so this thread does not get hijcked.
Mic is offline
Old 06-07-2008, 04:15 PM   #10
That is an excellent chassis. If I had some cash, and some berg axles I would be picking one up! Nice work.
Shaun is offline
Old 06-07-2008, 06:53 PM   #11
OCCUPY RCC!
dezfan's Avatar
I'll be running a ZERO on my Berg!
I'll take a chassis and electronics plate!
dezfan is offline
Old 06-07-2008, 09:50 PM   #12
Kamikaze's Avatar
Keep 'em commin guys, I got a few layin around!!
Kamikaze is offline
Old 06-07-2008, 10:25 PM   #13
i'll take a chassis
BoNuS LiNe is offline
Old 06-09-2008, 01:13 AM   #14
Rock Bender
ratterd's Avatar
sign me up for chassis and electronics plate thanx
ratterd is offline
Old 06-09-2008, 06:06 PM   #15
i would like a chassis and electronics plate.
thanks,
chris
sidewinder is offline
Old 06-09-2008, 10:29 PM   #16
Kamikaze's Avatar
Sorry for the delay, but here is the production servo plate, just so you don't think you are paing $20 for a peice of angle.....
It has a mount for a standard micro servo, and mounts for the radio shack switches that we are all using. I also incuded tie down slots for velcro straps to give your electronics that extra safty.
Kamikaze is offline
Old 06-09-2008, 10:38 PM   #17
OCCUPY RCC!
dezfan's Avatar
Looking good mang!
dezfan is offline
Old 06-10-2008, 04:01 PM   #18
Can't wait,more than ready to ditch those damn drive shafts!
Old 06-10-2008, 05:09 PM   #19
GSRCRC Prez
marzzz23's Avatar
great it works with Berg axles. I cant afford those, will the zero work with ax10 axles or tlt's?
marzzz23 is online now
Old 06-10-2008, 05:30 PM   #20
Kamikaze's Avatar
I just test drove the ax-10 rock racer I built this afternoon..... let me eat dinner and I will post pics. The chassis plates will bolt up to a stock ax-10 skid, or any other aftermarket skid that can use the stock sideplates.
Would you guys be interested in just buying the side plates?? I could sell them seperate for $45 shipped for the pair of side plates.
Kamikaze is offline
Closed Thread
You may edit your posts
