Go Back   RCCrawler.com Bulletin Board > Vendors > Vendors Market > Chassis and Suspension
Thread: CKRC Crawlers, The new Axial Bender SWX chassis is stock.
Old 10-24-2008, 01:57 PM   #1
KING BLING's Avatar
Default CKRC Crawlers, The new Axial Bender SWX chassis is stock.
Its here, the new Bender swx chassis from axial racing.
Bender Customs SWX Chassis Kit
If your driving style prefers a narrower chassis with just the right amount of suspension travel to maintain stability on any terrain, then you will demand the Bender Customs SWX. The SWX is the 4th generation of several years of chassis research and development.
  • Narrow chassis for squeezing through tight gaps
  • The originator of the "open sided motor plate".
  • Delrin skid plate wraps under the side plates to help you slide over the rocks better
  • Skid plate has a directional channel down the center to help prevent lateral slides when on the rocks
  • Counter sunk screws help prevent hang ups
  • Thick 3mm aluminum side plates provide a rigid chassis
  • Includes grey anodized links and bolts directly to any AX10 Scorpion
  • Complete easy to follow instructions makes it easy for anyone to install and setup
  • Allows the use of most transmissions and dig units currently on the market
CKRC not only has the axial SWX in stock, we also received the full line of replacement parts for the SWX line.
To get your SWX chassis for only $98.99, click Here; Axial SWX
KING BLING is offline   Reply With Quote
You may edit your posts
